1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: alarm handler on base 3-14-11
To: "Patrick Thomas" <[email protected]>
Cc: [email protected]
Date: Thu, 24 Sep 2009 00:44:36 -0500
This is what I see on my 64-bit Linux system:
[epics@baja ~]$ ls -l /usr/lib64/*curs*
lrwxrwxrwx 1 root root     19 Nov  2  2007 /usr/lib64/libXcursor.so.1 -> libXcursor.so.1.0.2
-rwxr-xr-x 1 root root  41040 Sep 24  2007 /usr/lib64/libXcursor.so.1.0.2
-rw-r--r-- 1 root root     17 Oct 16  2007 /usr/lib64/libcurses.so
lrwxrwxrwx 1 root root     18 Feb 20  2008 /usr/lib64/libcursesw.so -> libncursesw.so.5.6
lrwxrwxrwx 1 root root     27 Feb 20  2008 /usr/lib64/libncurses.so -> ../../lib64/libncurses.so.5
lrwxrwxrwx 1 root root     16 Feb 20  2008 /usr/lib64/libncursesw.so -> libncursesw.so.5
lrwxrwxrwx 1 root root     18 Nov  2  2007 /usr/lib64/libncursesw.so.5 -> libncursesw.so.5.6
-rwxr-xr-x 1 root root 183264 Oct 16  2007 /usr/lib64/libncursesw.so.5.6
Sent: Thu 9/24/2009 12:17 AM
To: Mark Rivers
Cc: Matthieu Bec; [email protected]
Subject: Re: alarm handler on base 3-14-11
It seems there were too many dependencies to remove, so I did a
reinstall, but that didn't seem to help, and it gave the same warning
that ldconfig did when it reinstalled.
Mark Rivers wrote:
> That's what I suspected.  I don't think that is right.  I would uninstall both packages, make sure those files are gone and reinstall.
> Mark
> ________________________________
> From: Patrick Thomas [mailto:[email protected]]
> Sent: Wed 9/23/2009 11:08 PM
> To: Mark Rivers
> /usr/lib/libcurses.so seems to be a link to /usr/lib64/libncurses.so.5.5
> Mark Rivers wrote:
>> Do
>> ls -l /usr/lib64/*curse*
>> and see what the real files are, what are soft links, etc.
>> From: [email protected] on behalf of Patrick Thomas
>> Sent: Wed 9/23/2009 10:54 PM
>> To: Matthieu Bec
>> It said:
>> /sbin/ldconfig: libraries libcurses.so and libncurses.so.5.5 in directory /usr/lib have same soname but different type.
>> Matthieu Bec wrote:
>>> Hi Patrick,
>>> try running ldconfig (as root), that might help fix missing softlink etc.
>>> and then rebuild as normal
>>> On 09/23/09 23:38, Patrick Thomas wrote:
>>>> I'm not sure. I see the path to /usr/lib64 being used by make, so I'm
>>>> confused why it wouldn't find it there.
>>>> /usr/bin/g++ -o alh
>>>> -L/users/thomas/epics/base/base-3-14-11/lib/linux-x86_64 -L/usr/lib64
>>>> -Wl,-rpath,/users/thomas/epics/base/base-3-14-11/lib/linux-x86_64
>>>> -Wl,-rpath,/usr/lib64 -m64 alCA.o acknowledge.o alAudio.o alarm.o
>>>> alCaCommon.o alConfig.o alFilter.o alLib.o alLog.o alView.o alh.o
>>>> awAct.o awAlh.o awEdit.o awView.o axArea.o axRunW.o axSubW.o browser.o
>>>> current.o dialog.o file.o force.o guidance.o heartbeat.o help.o line.o
>>>> mask.o process.o property.o scroll.o showmask.o sllLib.o beepSevr.o
>>>> noAck.o -lca -lCom -lXmu -lXm -lXt -lX11 -lXp -lpthread -lreadline
>>>> -lncurses -lm -lrt -ldl -lgcc
>>>> /usr/bin/ld: cannot find -lncurses
>>>> collect2: ld returned 1 exit status
>>>> make[3]: *** [alh] Error 1
>>>> make[3]: Leaving directory
>>>> `/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
>>>> make[2]: *** [install.linux-x86_64] Error 2
>>>> make[2]: Leaving directory
>>>> `/users/thomas/epics/extensions/src/alh1_2_24'
>>>> make[1]: *** [alh1_2_24.install] Error 2
>>>> make[1]: Leaving directory `/users/thomas/epics/extensions/src'
>>>> make: *** [src.install] Error 2
>>>> Zhichu Chen wrote:
>>>>> Then maybe your /usr/lib(64) is not included in the LIB variable. It
>>>>> happened to me before, when I was compiling EDM on a 64bit ubuntu
>>>>> using GCC 4.3.3, it can't find libXm, blahblah. Well, since that's not
>>>>> my laptop and I'm not supposed to jeopardize the system environment, I
>>>>> just make some symbolic links to /base/lib so it can move on to the
>>>>> next step. I'm not sure if this message could be helpful.
>>>>> On Thu, Sep 24, 2009 at 10:35 AM, Patrick Thomas
>>>>> <[email protected]> wrote:
>>>>>> There is a copy there as well.
>>>>>> Mark Rivers wrote:
>>>>>>> I think that is the 32-bit version, and you need the 64-bit version,
>>>>>>> which
>>>>>>> will be in usr/lib64
>>>>>>> Mark
>>>>>>> Sent: Wed 9/23/2009 9:02 PM
>>>>>>> To: Zhichu Chen
>>>>>>> I think it is installed, there is a libncurses.so.5 file in /usr/lib.
>>>>>>> Zhichu Chen wrote:
>>>>>>>> Install ncurses library by yourself.
>>>>>>>> On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
>>>>>>>>> Thank you, that seems to have worked. However, now it errors on
>>>>>>>>> 'cannot
>>>>>>>>> find
>>>>>>>>> -lncurses' for g++ -o alh.
>>>>>>>>> Mark Rivers wrote:
>>>>>>>>>> This is a common change required in 3.14.11.
>>>>>>>>>> You need to "#include menuYesNo.h" and YES needs to be changed to
>>>>>>>>>> menuYesNoYES.
>>>>>>>>>> Mark
>>>>>>>>>> Sent: Wed 9/23/2009 8:00 PM
>>>>>>>>>> To: [email protected]
>>>>>>>>>> Subject: alarm handler on base 3-14-11
>>>>>>>>>> Hi,
>>>>>>>>>> I was wondering, I get a compile error on force.c when running
>>>>>>>>>> make on
>>>>>>>>>> the alarm handler with epics-3-14-11, on 64 bit linux:
>>>>>>>>>> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>>>>>>>>>> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
>>>>>>>>>> -D_REENTRANT -O3 -Wall -m64 -g -I. -I../O.Common -I.
>>>>>>>>>> -I../os/default -I.. -I../../../include/os/Linux
>>>>>>>>>> -I../../../include
>>>>>>>>>> -I/users/thomas/epics/base/base-3-14-11/include/os/Linux
>>>>>>>>>> -I/users/thomas/epics/base/base-3-14-11/include -I../os/Linux
>>>>>>>>>> -I../os/default -I/usr/include -I/usr/include/X11 ../force.c
>>>>>>>>>> ../force.c: In function 'forcePVUpdateFields':
>>>>>>>>>> ../force.c:1028: error: 'YES' undeclared (first use in this
>>>>>>>>>> function)
>>>>>>>>>> ../force.c:1028: error: (Each undeclared identifier is reported
>>>>>>>>>> only
>>>>>>>>>> once
>>>>>>>>>> ../force.c:1028: error: for each function it appears in.)
>>>>>>>>>> make[2]: *** [force.o] Error 1
>>>>>>>>>> make[1]: *** [install.linux-x86_64] Error 2
>>>>>>>>>> make: *** [alh1_2_24.install] Error 2
>>>>>>>>>> Thank you,
>>>>>>>>>> Patrick
Re: alarm handler on base 3-14-11 Patrick Thomas
Re: alarm handler on base 3-14-11 Thomas Birke
RE: alarm handler on base 3-14-11 Mark Rivers
Re: alarm handler on base 3-14-11 Zhichu Chen
Re: alarm handler on base 3-14-11 Matthieu Bec
Prev: Re: alarm handler on base 3-14-11 Patrick Thomas
Next: Re: alarm handler on base 3-14-11 Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
