1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: makeBaseApp -t ioc missing Makefile
To: Zhichu Chen <[email protected]>
Cc: [email protected]
Date: Mon, 21 Sep 2009 18:45:27 -0700
Yes, I think your right. I changed the permissions of the folder that I was creating the ioc in with chmod 777 and it worked. I'm not quite sure I understand why though. Both the folder that I am putting the ioc in and the copy of base that I am using are owned by the same user that I am logged in as. How does this work?
Thank you,
Patrick
Zhichu Chen wrote:
Well, could be a permission problem. Have you tried "sudo"?
On Sat, Sep 19, 2009 at 11:40 AM, Patrick Thomas
<[email protected]> wrote:
Yes, there is a Makefile there.
-Patrick
Zhichu Chen wrote:
Are you sure your "base" is made successfully without any errors? You
can check your base/templates/makeBaseApp/top/iocApp to see if there's
Makefile there. makeBaseApp.pl just copy the files and do some macros
replacements I think.
On Sat, Sep 19, 2009 at 8:42 AM, Patrick Thomas
and I have 3-14-11 instead of 3-14-11-asdl
Eric Norum wrote:
Seems to work here:
norume 233>
/usr/local/iocapps/R3.14.11/base/3-14-11-asd1/bin/darwin-x86/makeBaseApp.pl
-t ioc blah
norume 234> ls -R
Makefile    blahApp        configure
./blahApp:
Db        Makefile    src
./blahApp/Db:
Makefile
./blahApp/src:
Makefile    blahMain.cpp
./configure:
CONFIG        Makefile    RULES        RULES_DIRS
CONFIG_SITE    RELEASE        RULES.ioc    RULES_TOP
On Sep 18, 2009, at 5:15 PM, Patrick Thomas wrote:
I was trying to run makeBaseApp -t ioc with epics 3-14-11, and I
noticed
that it did not put a Makefile in the directory. It only creates the
application directory and the configure directory. Is this correct?
Thank you,
Patrick
Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
makeBaseApp -t ioc missing Makefile Patrick Thomas
Re: makeBaseApp -t ioc missing Makefile Eric Norum
Re: makeBaseApp -t ioc missing Makefile Patrick Thomas
Prev: Re: Spring Meeting 2010? Ernest L. Williams Jr.
Next: web page for EPICS meeting in Kobe, Oct. 11,2009. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
Next: Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
