The makeBaseApp.pl script may have something to do with the permission
issue. I'm not very familiar with perl so I can't say that it's not
possible that this script uses another "special" account to copy the
file which is not allowed.
I don't quite know linux either. But this is kind of off topic.
I'm glad you've "solved" the problem ;)
On Tue, Sep 22, 2009 at 9:45 AM, Patrick Thomas
<[email protected]> wrote:
> Yes, I think your right. I changed the permissions of the folder that I was
> creating the ioc in with chmod 777 and it worked. I'm not quite sure I
> understand why though. Both the folder that I am putting the ioc in and the
> copy of base that I am using are owned by the same user that I am logged in
> as. How does this work?
> Thank you,
> Patrick
> Zhichu Chen wrote:
>> Well, could be a permission problem. Have you tried "sudo"?
>> On Sat, Sep 19, 2009 at 11:40 AM, Patrick Thomas
>>> Yes, there is a Makefile there.
>>> -Patrick
>>> Zhichu Chen wrote:
>>>> Are you sure your "base" is made successfully without any errors? You
>>>> can check your base/templates/makeBaseApp/top/iocApp to see if there's
>>>> Makefile there. makeBaseApp.pl just copy the files and do some macros
>>>> replacements I think.
>>>> On Sat, Sep 19, 2009 at 8:42 AM, Patrick Thomas
>>>>> and I have 3-14-11 instead of 3-14-11-asdl
>>>>> Eric Norum wrote:
>>>>>> Seems to work here:
>>>>>> norume 233>
>>>>>> /usr/local/iocapps/R3.14.11/base/3-14-11-asd1/bin/darwin-x86/makeBaseApp.pl
>>>>>> -t ioc blah
>>>>>> norume 234> ls -R
>>>>>> Makefile blahApp configure
>>>>>> ./blahApp:
>>>>>> Db Makefile src
>>>>>> ./blahApp/Db:
>>>>>> Makefile
>>>>>> ./blahApp/src:
>>>>>> Makefile blahMain.cpp
>>>>>> ./configure:
>>>>>> CONFIG Makefile RULES RULES_DIRS
>>>>>> CONFIG_SITE RELEASE RULES.ioc RULES_TOP
>>>>>> On Sep 18, 2009, at 5:15 PM, Patrick Thomas wrote:
>>>>>>> Hi,
>>>>>>> I was trying to run makeBaseApp -t ioc with epics 3-14-11, and I
>>>>>>> noticed
>>>>>>> that it did not put a Makefile in the directory. It only creates the
>>>>>>> application directory and the configure directory. Is this correct?
>>>>>>> Thank you,
>>>>>>> Patrick
Best Regards
Chen
Zhi-chu Chen | Shanghai Synchrotron Radiation Facility
No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China
tel: 086 21 5955 3405 | zhichu.chen.googlepages.com
| www.sinap.ac.cn
- makeBaseApp -t ioc missing Makefile Patrick Thomas
- Re: makeBaseApp -t ioc missing Makefile Eric Norum
- Re: makeBaseApp -t ioc missing Makefile Patrick Thomas
- Re: makeBaseApp -t ioc missing Makefile Zhichu Chen
web page for EPICS meeting in Kobe, Oct. 11,2009. Noboru Yamamoto
What is all I need to know to write a CA protocal? Zhichu Chen
<2009>
<2009>
