HI,
I have another question about CAJ, relating to the property
"max_array_bytes".
I am not setting the "max_array_bytes" property in a properties file
or
in my application. When I call context.printInfo in my running
application I get the following:
context.printfInfo ****************************
CLASS : com.cosylab.epics.caj.CAJContext
ADDR_LIST : localhost 164.54.160.255
AUTO_ADDR_LIST : false
CONNECTION_TIMEOUT : 30.0
BEACON_PERIOD : 15.0
REPEATER_PORT : 5065
SERVER_PORT : 5064
MAX_ARRAY_BYTES : 16384
The value of MAX_ARRAY_BYTES is 16384, the default, as I expect.
However, my application is using CAJ to read arrays that are over
1.2MB
with no errors! Is the max_array_bytes property actually not used in
CAJ? It looks like it must be being ignored?
Well, CAJ does not ignore this property. It preallocates its buffers
using MAX_ARRAY_BYTES value.
However, if server sends a bigger array it replaces buffer with newly
allocated (bigger one).
(This is not optimal regarding resource allocation, but it's very
convenient on client side. I can put a "hard" limit there, if you
wish...)
Matej
- RE: CAJ questions Mark Rivers
- Re: CAJ questions Matej Sekoranja
FW: EDM: Text Monitor Widget Szalata, Zenon M.
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
