I have 2 questions about CAJ, the native Java Channel Access client
implementation.
1) It seems like it behaves differently on computers with multiple
network interfaces from the C implementation. On the C
implementation
by default the broadcast address of each the networks is used when
searching for PVs. On the CAJ implementation this does not seem to
be
the case. It is not finding PVs on one of these networks with the
default configuration, in my case on the 10.20.1.x subnet. However,
if I set the following in my configuration file then it does work:
gov.aps.jca.Context.auto_addr_list= false
gov.aps.jca.Context.addr_list= 10.20.1.255
Is this an intended difference in behavior from the C implementation,
and if so is it documented?
Until Java 1.6, there was no (clean) way to "introspect" network
interfaces to get broadcast address of all. Therefore, CAJ uses
255.255.255.255 (auto) or be configured manually.
Java 1.6 supports this, but I do not want drop support for Java 1.5.
(Well, in fact I do a small "hack": compile code as 1.5 compatible,
detect Java version and use appropriate code).
2) My second question relates to knowing how to create configuration
lines such as those above in the JCALibrary.properties file.
The documentation links in the CAJ User Manual here:
http://caj.cosylab.com/manual.html
Include this one labelled "JCA tutorial on configuration":
http://www.aps.anl.gov/bcda/jca/jca/2.1.2/tutorial.html
But that tutorial only lists configuration lines like these:
gov.aps.jca.jni.JNIContext.addr_list= toto.uses.this.ca.server
gov.aps.jca.jni.JNIContext.auto_addr_list= false
These are for the JNI (e.g. C) implementation, not for the native
Java
implementation.
See
http://jca.cosylab.com/apidocs/gov/aps/jca/JCALibrary.html#CHANNEL_ACCESS_JAVA
for native CAJ options.
However you can use "gov.aps.jca.Context." prefix to configure all CA
java implementations, but note that specific configuration (prefix)
overrides the general one.
There is another link on the CAJ User Manual Page which is labelled
as
"CAJ configuration properties":
http://www.cosylab.com/jca/apidocs/gov/aps/jca/JCALibrary.html#CHANNEL_
ACCESS_JAVA
Link about is the right one now. Fixed. Thanks.
Cheers,
Matej
- RE: CAJ questions Mark Rivers
RE: Asyn R4.11 Mark Rivers
RE: Asyn R4.11 Szalata, Zenon M.
<2009>
<2009>
