Hi Matej,
> (This is not optimal regarding resource allocation, but it's very
> convenient on client side. I can put a "hard" limit there, if you
> wish...)
I agree that it is very convenient for clients, and I am happy to keep
the current behavior. I just wanted to make sure that I understood how
it works.
-----Original Message-----
Sent: Wednesday, August 05, 2009 7:12 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: CAJ questions
HI,
> I have another question about CAJ, relating to the property
> "max_array_bytes".
> I am not setting the "max_array_bytes" property in a properties file
> or
> in my application. When I call context.printInfo in my running
> application I get the following:
> context.printfInfo ****************************
> CLASS : com.cosylab.epics.caj.CAJContext
> ADDR_LIST : localhost 164.54.160.255
> AUTO_ADDR_LIST : false
> CONNECTION_TIMEOUT : 30.0
> BEACON_PERIOD : 15.0
> REPEATER_PORT : 5065
> SERVER_PORT : 5064
> MAX_ARRAY_BYTES : 16384
> The value of MAX_ARRAY_BYTES is 16384, the default, as I expect.
> However, my application is using CAJ to read arrays that are over
> 1.2MB
> with no errors! Is the max_array_bytes property actually not used in
> CAJ? It looks like it must be being ignored?
Well, CAJ does not ignore this property. It preallocates its buffers
using MAX_ARRAY_BYTES value.
However, if server sends a bigger array it replaces buffer with newly
allocated (bigger one).
wish...)
Matej
- Re: CAJ questions Matej Sekoranja
- RE: CAJ questions Mark Rivers
CA reconnection problem Dirk Zimoch
<2009>
IOC crash when asyn traceflow turned on Shifu Xu
<2009>
