g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Subject: caget return timeout
From: "Roberto Capobianco" <roberto.capobianco@igi.cnr.it>
To: <tech-talk@aps.anl.gov>
Date: Wed, 7 Jan 2009 10:34:47 +0100
Hi all,
I am new to Epics world. This is my problem.
I installed epics 3.14 on two machines, one with fedora 10 and one with Windows XP SP3. No problem here.
I want to try the communication between them.
So i built an application from example template on both the machines. No problem here.
Then on the linux machine i setted the variables
export EPICS_CA_ADDR_LIST=(windows ip)
export EPICS_CA_AUTO_ADDR_LIST=NO
and on the windows machine i setted the variables
set EPICS_CA_ADDR_LIST=(linux ip)
set EPICS_CA_AUTO_ADDR_LIST=NO
I launched the applications without any error. I can see PVs with dbl command on both the machines.
Ok. Now when i do the command caget userHost:aiExample on the linux machine i can read the value but
when i do the same command on the windows machine caget return the message "Channel connect timed out: userHost:aiExample not found".
The user is different between the two machines.
caRepeater is running on both machines.
What's wrong ? Thank You.
Robert
Re: caget return timeout Mauro Giacchini
Re: caget return timeout Ralph Lange
Prev: RTYP field through the PV Gateway Ernest L. Williams Jr.
Next: Re: caget return timeout Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013
Prev: RE: RTYP field through the PV Gateway Jeff Hill
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
