May you start checking:
All Windows firewalls are turned off ?
All Linux firewalls are turned off ?
Both machine are into the same subnet? (ie LinuxIP = a.b.c.x and WinIP =
a.b.c.y ?)
Hope this helps,
Mauro.
Roberto Capobianco wrote:
Hi all,
I am new to Epics world. This is my problem.
I installed epics 3.14 on two machines, one with fedora 10 and one
with Windows XP SP3. No problem here.
I want to try the communication between them.
So i built an application from example template on both the machines.
No problem here.
Then on the linux machine i setted the variables
export EPICS_CA_ADDR_LIST=(windows ip)
export EPICS_CA_AUTO_ADDR_LIST=NO
and on the windows machine i setted the variables
set EPICS_CA_ADDR_LIST=(linux ip)
set EPICS_CA_AUTO_ADDR_LIST=NO
I launched the applications without any error. I can see PVs with dbl
command on both the machines.
Ok. Now when i do the command caget userHost:aiExample on the linux
machine i can read the value but
when i do the same command on the windows machine caget return the
message "Channel connect timed out: userHost:aiExample not found".
The user is different between the two machines.
caRepeater is running on both machines.
What's wrong ? Thank You.
Robert
Mauro Giacchini
Istituto Nazionale di Fisica Nucleare - Laboratori Nazionali di Legnaro
V.le dell’Universita', 2
35020 LEGNARO (PD) – ITALY
Tel. +39.049.8068558
Fax. +39.049.641925
EPICS _at_ LNL: http://www.lnl.infn.it/~epics/
- caget return timeout Roberto Capobianco
Re: caget return timeout Ralph Lange
<2009>
<2009>
