Summarizing the issue; this PV attribute, "DBR_CLASS_NAME", isn't currently
maintained in the gateway's cache. The symptom must be that its
communicating properly through both sides of CA, but not through the
gateway.
I am not aware that anyone is working on this, but Ralph Lange would be the
best person to consult concerning current projects in progress with the
gateway.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Wednesday, January 07, 2009 8:29 AM
> To: [email protected]
> Cc: Ernest L. Williams Jr.
> Subject: Re: RTYP field through the PV Gateway
> Hi Ernest,
> On Wednesday 07 January 2009 00:15:17 Ernest L. Williams Jr. wrote:
> > Is anyone working to add the "DBR_CLASS_NAME" to the gateway so that it
> > handles the RTYP field in an EPICS record?
> I'm not aware of anybody doing so. Why can't you just ask for the .RTYP
> field
> name (which is really an automatically created record attribute) directly?
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold Welte
- RTYP field through the PV Gateway Ernest L. Williams Jr.
- Re: RTYP field through the PV Gateway Andrew Johnson
Re: initial(init_value) rule within a field sometimes works - follow up Andrew Johnson
EPICs base MingW32 compilation failed ! URIOT Didier
<2009>
caget return timeout Roberto Capobianco
<2009>
