Could you please share a little more
information ?
How do you link your application?
Could you attach the (complete) console
log of the build process (compilation/linking) ?
What EPICS version are you using?
Thanks
- Till
师昊礼 wrote:
> Hi, all
> I built an epics application, and I used two functions like this:
> #include <devLib.h>
> char *localaddrstart;
> unsigned short int testvalue=INIT_TESTVALUE;
> unsigned long baseaddr = 0x20200000;
> if (devRegisterAddress("VME_mapping", atVMEA32, baseaddr, sizeof(struct
> channel), (char *) &(localaddrstart))!=0)
> printf("Out of Bus Mem Map!\n");
> return -1;
> if (devReadProbe(1, localaddrstart, &testvalue) < 0)
> printf("No board at this address!\n");
> return -1;
> then, I past the compilation, but when I download the object file to the
> target board, and there are the following errors:
> ld("../bin/RTEMS-mvme5500/power_supply.obj")
> Unresolved symbol: pdevLibVirtualOS
> any help is appreciated, thanks a lot!
> Haoli Shi
- epics functions application problem(2) 师昊礼
Note: connection issues with alh option -desc_field Kasemir, Kay (ky9)
<2008>
<2008>
