Subject: epics functions application problem(2)
To: [email protected]
Date: Wed, 23 Jul 2008 21:18:38 +0800
Hi, all
   I built an epics application, and I used two functions like this:
   #include <devLib.h>
   char	*localaddrstart;
   unsigned short int testvalue=INIT_TESTVALUE;
   unsigned long baseaddr = 0x20200000;
   if (devRegisterAddress("VME_mapping", atVMEA32, baseaddr, sizeof(struct
channel), (char *) &(localaddrstart))!=0)
		printf("Out of Bus Mem Map!\n");
		return -1;
   if (devReadProbe(1, localaddrstart, &testvalue) < 0)
	  printf("No board at this address!\n");
	  return -1;
   then, I past the compilation, but when I download the object file to the
target board, and there are the following errors:
   ld("../bin/RTEMS-mvme5500/power_supply.obj")
   Unresolved symbol: pdevLibVirtualOS
any help is appreciated, thanks a lot!
Haoli Shi
Re: epics functions application problem(2) Till Straumann
Prev: Re: array calc / inverse subarray survey? Andrew Johnson
Next: Re: epics functions application problem(2) Till Straumann
Prev: procServ soft IOC server - V2.4.0 released Ralph Lange
