Subject: Building motor6-3 record
To: [email protected]
Date: Thu, 03 Apr 2008 15:08:02 -0700
Hello all
We are trying valiantly but unsuccessfully to build the motor record 6-3 to incorporate the Galil motor driver from ALS (a non-asyn device driver). In trying to build the NoAsyn example of the motor record, we are constantly encountering the requirement to have asyn. We have not yet tried this on a clean install of base, but suspect there may be some debris from our asyn build (used for another project) leaking over into the motor record build. Has anyone experienced this, and found a solution?
Thanks in advance.
RE: Building motor6-3 record Mark Rivers
Re: Building motor6-3 record Ron Sluiter
Prev: Re: cross subnet CA communication Sue Witherspoon
Next: genSub and capture monitor event Emmanuel Mayssat
Prev: New Perl 5 CA module Andrew Johnson
Next: RE: Building motor6-3 record Mark Rivers
