David,
I am not familiar with the Galil driver, but here is something to be
aware of.
The are 2 different uses of asyn in the "motor" module.
1) As the low-level interface between the motor record drivers and
serial or TCP/IP devices. This use is quite old, and is used by many
"non-asyn" device drivers.
2) As a medium level interface between motor record device support and
new drivers. This is a relatively new development, with an asyn device
support and driver support that are both device-independent. This is
probably what you meant by "asyn drivers".
So it is possible that you are building the motor module with drivers
that are not in category 2, but still needs asyn because they are in
category 1.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of David Morris
> Sent: Thursday, April 03, 2008 4:08 PM
> To: [email protected]
> Subject: Building motor6-3 record
> Hello all
> We are trying valiantly but unsuccessfully to build the
> motor record
> 6-3 to incorporate the Galil motor driver from ALS (a non-asyn device
> driver). In trying to build the NoAsyn example of the motor
> record, we
> are constantly encountering the requirement to have asyn. We have not
> yet tried this on a clean install of base, but suspect there
> may be some
> debris from our asyn build (used for another project) leaking
> over into
> the motor record build. Has anyone experienced this, and
> found a solution?
> Thanks in advance.
- Building motor6-3 record David Morris
genSub and capture monitor event Emmanuel Mayssat
Re: genSub and capture monitor event Eric Norum
<2008>
Re: Building motor6-3 record Ron Sluiter
<2008>
