Subject: New Perl 5 CA module
To: EPICS tech-talk <[email protected]>
Date: Thu, 03 Apr 2008 10:58:17 -0500
I've been working on a CA client library interface module for Perl 5, since all of the existing ones I know of use EZCA (which I don't like). A version of this code will probably be included in Base R3.14.10, but I'm making it available now since it works fine with R3.14.9 and I would like some outside testing first.
For test and example purposes I have reimplemented the cainfo, caget, caput and camonitor programs from Base in Perl, although my versions are not as comprehensive as Ralph's C originals. The code has been tested on Solaris, Linux and Darwin/Mac OS X; I have no idea whether it will build or run on Windows, but I'd be interested in feedback or patches if someone manages to make it work there.
Requires: Perl 5.8.x, tested on 5.8.6 and 5.8.8.
The source code can be found in the EPICS Modules Download area at
  http://www.aps.anl.gov/epics/download/modules/cap5-0.1.tgz
Documentation (using Perl's POD format) is included in the package and will be converted to HTML at build time, or it can be read online at
http://www.aps.anl.gov/epics/modules/soft/cap5/
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Prev: Re: cross subnet CA communication Sue Witherspoon
Next: Re: cross subnet CA communication Sue Witherspoon
Prev: Re: cross subnet CA communication Paul Sichta
Next: Building motor6-3 record David Morris
