Dear all,
I am trying to communicate the GPIB device with a NI-PCI board. I have built base-3.14.9,StreamaDevice-2-3,asyn4-7 with LINUX_GPIB=yes ,linux-gpib-3.2.09
and the board driver NI-488.2-beta-2.5.1b0 on the RHEL4. When I run the application, there are always errors.especially "Command GpibBoardDriverConfig not found". [fel@localhost iocPSM6003]$ ../../bin/linux-x86/PSM6003 st.cmd #!../../bin/linux-x86/PSM6003 ## You may have to change PSM6003 to something else ## everywhere it appears in this file < envPaths epicsEnvSet(ARCH,"linux-x86") epicsEnvSet(IOC,"iocPSM6003") epicsEnvSet(TOP,"/home/fel/psm6003/psm6003") epicsEnvSet(PSM6003,"/home/fel/psm6003/module/psm6003") epicsEnvSet(ASYN,"/home/fel/psm6003/asyn4-7") epicsEnvSet(EPICS_BASE,"/home/fel/psm6003/base") epicsEnvSet ("STREAM_PROTOCOL_PATH", "../../PSM6003APP/Db:.") ## Register all support components dbLoadDatabase("../../dbd/PSM6003.dbd",0,0) PSM6003_registerRecordDeviceDriver(pdbbase) ## Load record instances dbLoadRecords("../../db/devPSM6003.db","P=PSM6003:,R=,L=0,A=0") GpibBoardDriverConfig("L0",1,0,3,0) st.cmd -- Line 15 -- Command GpibBoardDriverConfig not found. iocInit() Starting iocInit ############################################################################ ## EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$ ## EPICS Base built Jan 17 2008 ############################################################################ 2008/01/18 17:13:41.457 Businterface 'L0' not found for 'query-current' 2008/01/18 17:13:41.458 query-current: Can't attach to bus L0 0 2008/01/18 17:13:41.458 query-current: Record initialization failed 2008/01/18 17:13:41.458 Businterface 'L0' not found for 'setcurrent' 2008/01/18 17:13:41.458 setcurrent: Can't attach to bus L0 0 2008/01/18 17:13:41.458 setcurrent: Record initialization failed iocInit: All initialization complete ## Start any sequence programs #seq sncPSM6003,"user=fel" The CA server's beacon address list was empty after initialization? epics> many thanks in advance
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
