Subject: Re: error in communicating to the GPIB device with NI-PCI board
To: [email protected]
Date: Fri, 18 Jan 2008 11:59:59 +0100
Hello,
On Freitag, Jan 18 2008, zhangdemin99 wrote:
>   I am trying to communicate the GPIB device with a NI-PCI board.
> I have built base-3.14.9,StreamaDevice-2-3,asyn4-7 with LINUX_GPIB=yes
> ,linux-gpib-3.2.09
> and the  board driver NI-488.2-beta-2.5.1b0 on the RHEL4.
You should have something like
=== /etc/gpib.conf ===
interface {
        minor = 0
        board_type = "ni_pci"
        name = "L0"
        pad = 0
        sad = 0
        timeout = T3s
        eos = 0x0a
        set-reos = yes
        set-bin = no
        set-xeos = no
        set-eot = yes
        master = yes
in /etc/gpib.conf. You need to use something else than 0 for the pad (primary
address) setting of the board, if your device itself really has address 0.
Verify your setup with ibtest!
>   When I run the application, there are always errors.especially
> "Command GpibBoardDriverConfig not found".
> [fel@localhost iocPSM6003]$ ../../bin/linux-x86/PSM6003 st.cmd
> #!../../bin/linux-x86/PSM6003
> ## You may have to change PSM6003 to something else
> ## everywhere it appears in this file
> < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iocPSM6003")
> epicsEnvSet(TOP,"/home/fel/psm6003/psm6003")
> epicsEnvSet(PSM6003,"/home/fel/psm6003/module/psm6003")
> epicsEnvSet(ASYN,"/home/fel/psm6003/asyn4-7")
> epicsEnvSet(EPICS_BASE,"/home/fel/psm6003/base")
> epicsEnvSet ("STREAM_PROTOCOL_PATH", "../../PSM6003APP/Db:.")
> ## Register all support components
> dbLoadDatabase("../../dbd/PSM6003.dbd",0,0)
> PSM6003_registerRecordDeviceDriver(pdbbase)
> ## Load record instances
> dbLoadRecords("../../db/devPSM6003.db","P=PSM6003:,R=,L=0,A=0")
This looks wrong to me. You have to pass the "L0" name to the database. Are
you sure your device is at address 0? For your device at GPIB address 15, it
should look like
dbLoadRecords("../../db/devPSM6003.db","P=PSM6003:,PORT=L0,ADDR=15")
> GpibBoardDriverConfig("L0",1,0,3,0)
> st.cmd -- Line 15 -- Command GpibBoardDriverConfig not found.
You are missing
PSM6003_DBD += drvLinuxGpib.dbd
in PSM6003App/src/Makefile. See my lengthy post in your other thread.
> iocInit()
> Starting iocInit
># ## EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$
> ## EPICS Base built Jan 17 2008
># 2008/01/18 17:13:41.457 Businterface 'L0' not found for 'query-current'
> 2008/01/18 17:13:41.458 query-current: Can't attach to bus L0 0
> 2008/01/18 17:13:41.458 query-current: Record initialization failed
> 2008/01/18 17:13:41.458 Businterface 'L0' not found for 'setcurrent'
> 2008/01/18 17:13:41.458 setcurrent: Can't attach to bus L0 0
> 2008/01/18 17:13:41.458 setcurrent: Record initialization failed
> iocInit: All initialization complete
> ## Start any sequence programs
> #seq sncPSM6003,"user=fel"
> The CA server's beacon address list was empty after initialization?
> epics>
That final message regarding CA server beacon address looks suspicious, but
can maybe ignored.
Again: make sure you can talk to the device using ibtest first.
-Stefan
Stefan Heim, PhD Student X-ray microscopy
BESSY mbH, Albert-Einstein-Straße 15, D-12489 Berlin, Germany
voice: +49 30 6392 3177 fax: + 49 30 6392 4757 e-mail: [email protected]
BESSY mbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
Geschäftsführer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard
Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
Re: error in communicating to the GPIB device with NI-PCI board Stefan Heim
error in communicating to the GPIB device with NI-PCI board zhangdemin99
Prev: error in communicating to the GPIB device with NI-PCI board zhangdemin99
Next: Re: CA connection management problem Andrew Johnson
Next: Re: error in communicating to the GPIB device with NI-PCI board Stefan Heim
