1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 250kV ION source control
To: Heinrich du Toit <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 14 Nov 2007 07:32:21 -0800
When the Front End of the Spallation Neutron Source was built, we had the same challenge, but 60kV instead of 250kV. We solved it rather nicely with units from GMW Associates called "Group3". In particular, we found the "CNA" unit with 1 AO, 2 AI, 8 BI, 8 BO and some other nice attributes (such as diagnostics, filtering, etc) worked very well for a power supply. (They have other units to control motors, etc, called "DI".)
Carl Lionberger at LBL <[email protected]> did the drv and dev support for VxWorks. The connecting fiber was quite cheap. The ground end controller can be VME (our choice) as well as ISA, PCI, etc.
Contact either Brian Richter <[email protected]> or Ian Walker <[email protected]> and visit http://www.gmw.com/distributed_io/Group3Control/G3Control.html.
At 11:59 AM +0200 2007/11/14, Heinrich du Toit wrote:
Hi there
We have an Multi-sample ion source of negative ions by Ceium sputtering for AMS application.
The thing sits at 250kV's
The Power Supplies also sits at 250kV's.
We need to control these power supplies to control the ioc source.
Now the 250kV makes for some problems.
One solution would be to put a PC up at 250kV.. but then you have no local control (unless you put yourself at 250kV somehow) but only remote (ssh) access. And there is the danger that a spark or something could easily kill the PC :(
The other solution is to put the PC down at ground and then communicate using some fiber-link.
fiber-links are expensive so we would like to only use 1 of them for all the power-supply units.
So I was thinking maybe RS485 protocol.
Maybe somebody did work on this type of problem already and have something that could help us?
thanks
-Heinrich
250kV ION source control Heinrich du Toit
Prev: Latest IP Card Drivers for IOC Blade 9010 Darrell Nineham
Next: RE: help Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: 250kV ION source control Heinrich du Toit
Next: Re: 250kV ION source control Emmanuel Mayssat
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
