On Wed, 2007-11-14 at 11:59 +0200, Heinrich du Toit wrote:
> Hi there
> We have an Multi-sample ion source of negative ions by Ceium sputtering
> for AMS application.
> So I was thinking maybe RS485 protocol.
If you were thinking about differential communication over copper wire,
this wouldn't work. If you look at the specs of anything that can be
configured as differential (ADC, DAC, serial,...), you will read that
ground potential + max differential voltage as to be within a range.
With your 250V offset, you probably don't meet that specification.
Opto-coupling may be the only solution.
E
- 250kV ION source control Heinrich du Toit
RE: help Jeff Hill
Power Supply Record? Susanna Jacobson
<2007>
Re: 250kV ION source control Steve Lewis
Latest IP Card Drivers for IOC Blade 9010 Darrell Nineham
<2007>
