1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: same PV on multiple IOC's - side effect
To: "'Emmanuel Mayssat'" <[email protected]>, "'Andrew Johnson'" <[email protected]>
Cc: "'TechTalk EPICS'" <[email protected]>
Date: Thu, 27 Sep 2007 10:42:53 -0600
> Before I try and for those of us who use non-standard an dmultiple
> ports, can I simply set
> EPICS_CA_ADDR_LIST="<broadcast>:<port#1> <broadcast>:<port#2>"
Yes, that configuration option is supported. You might also decide to set
EPICS_CA_AUTO_ADDR_LIST=NO.
It's a bit more complicated when more than one port is in use to make
certain that the client sees all of the server beacons because the CA
repeater configuration is more complex.
What is the downside of the client not seeing all of the server beacons?
First, a long lifespan client might be slower connecting to a newly
introduced server(clients search a bit faster for awhile shortly after a new
beacon is seen). Second, the client might use a small amount of additional
network bandwidth periodically checking idle TCP circuits for responsiveness
(if the beacon isn't seen the client periodically verifies the idle tcp
circuit with a roundtrip message).
Jeff
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Emmanuel Mayssat
> Sent: Thursday, September 27, 2007 10:26 AM
> To: Andrew Johnson
> Cc: TechTalk EPICS
> Subject: Re: same PV on multiple IOC's - side effect
> Andrew,
> On Thu, 2007-09-27 at 10:48 -0500, Andrew Johnson wrote:
> > To tell the client library to only search the control network, set
> the
> > following two environment variables
> >    EPICS_CA_ADDR_LIST=<broadcast address of control subnet>
> > The broadcast address is shown on the output from /sbin/ifconfig -a
> and
> > is probably 172.16.4.255 but it may have different numbers in the 3rd
> or
> > 4th positions.
> Emmanuel
RE: same PV on multiple IOC's - side effect Emmanuel Mayssat
same PV on multiple IOC's - side effect Heinrich du Toit
Re: same PV on multiple IOC's - side effect Andrew Johnson
Re: same PV on multiple IOC's - side effect Emmanuel Mayssat
Prev: Re: same PV on multiple IOC's - side effect Emmanuel Mayssat
Next: RE: Learning EDM Denison, PN (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: same PV on multiple IOC's - side effect Emmanuel Mayssat
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
