Heinrich du Toit wrote:
Do you ever expect to have any IOCs on the campus network at all? If not, the solution is to configure the CA client library to send CA searches only to the control network. It is not possible with the current code to tell the IOC server to only export its PVs to a particular network on a machine with multiple interfaces, but as long as the clients only search one network they won't see the problem (for the purposes of the above explanation, the IOC is a client as well as a server). To tell the client library to only search the control network, set the following two environment variables EPICS_CA_AUTO_ADDR_LIST=NO EPICS_CA_ADDR_LIST=<broadcast address of control subnet> The broadcast address is shown on the output from /sbin/ifconfig -a and is probably 172.16.4.255 but it may have different numbers in the 3rd or 4th positions. As long as those variables are set before you start the IOC and/or any other clients you shouldn't see the duplicate PV warning. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
