On Thursday 20 September 2007 16:16, Eric Norum wrote:
> It appears to be faulting inside the RPC library clnttcp_create
> routine. Are there any diagnostics you can enable for that library?
> Do you have the source so you could check what's happening in the
> library code?
Having a hard time to believe that the RPC implementation is at fault here,
I pursued a different path and with success. The backtrace is misleading
(or should I say, wrong?), since the point where the IOC crashes is really
in clnt_destroy, not in clnttcp_create.
The fault, it seems, is in the routine vxiConnectPort (in
asyn/vxi11/drvVxi11.c). vxiConnectPort calls clnttcp_create and afterwards
calls vxiBusStatus. If vxiBusStatus fails, vxiConnectPort calls
ctln_destroy. However, if vxiBusStatus fails it has already called
clnt_destroy, since it is implemented using clntCall, which calls
vxiDisconnectPort on failure, which calls clnt_destoy.
Thus, clnt_destroy gets called a second time, causing the crash.
I have veryfied all this multiple times by adding enough breakpoints (all
call sites of clnt_create (1) and clnt_destroy (7) in
I have not produced a fix for this problem. I guess you (Eric) know better
how to approach this.
Cheers
Ben
- Re: Asyn/VXI-11 problems Benjamin Franksen
- Asyn/VXI-11 problems Benjamin Franksen
- Re: Asyn/VXI-11 problems Eric Norum
Re: exceed David Kline
<2007>
<2007>
