After I saw Guy's reply, I took a look at libgpib.la, and he is
correct. Turns out, libgpib.so is in the same directory as libgpib.la
(/usr/local/lib). So, I decided to set LD_LIBRARY_PATH to
/usr/local/bin.
This worked as far as the problem I had: I now do get pass libgpib.a
issue. However, I now get this error:
/usr/bin/ar -rc libasyn.a asynManager.o
epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o
drvAsynIPPort.o drvAsynIPServerPort.o asynInt32Base.o
asynInt32SyncIO.o asynInt32ArrayBase.o asynUInt32DigitalBase.o
asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o
asynFloat64ArrayBase.o asynOctetBase.o asynOctetSyncIO.o
asynCommonSyncIO.o asynShellCommands.o asynInterposeEos.o
asynInterposeFlush.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o
devAsynInt32Array.o devAsynUInt32Digital.o devAsynFloat64.o
devAsynFloat64Array.o asynRecord.o drvAsyn.o vxi11core_xdr.o
drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o devCommonGpib.o
devSupportGpib.o boSRQonOff.o drvLinuxGpib.o
/usr/bin/ranlib libasyn.a
Installing library ../../lib/linux-x86/libasyn.a
/usr/bin/ranlib ../../lib/linux-x86/libasyn.a
/usr/bin/g++ -o libasyn.so -shared -fPIC
-L/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86
-L/home/sysuser/epics.3.14.9/base-3.14.9/lib/linux-x86/
-Wl,-rpath,/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86
-Wl,-rpath,/home/sysuser/epics.3.14.9/base-3.14.9/lib/linux-x86/
asynManager.o epicsInterruptibleSyscall.o asynGpib.o
drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o
asynInt32Base.o asynInt32SyncIO.o asynInt32ArrayBase.o
asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o
asynFloat64SyncIO.o asynFloat64ArrayBase.o asynOctetBase.o
asynOctetSyncIO.o asynCommonSyncIO.o asynShellCommands.o
asynInterposeEos.o asynInterposeFlush.o devAsynOctet.o
asynEpicsUtils.o devAsynInt32.o devAsynInt32Array.o
devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat64Array.o
asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o
E2050Reboot.o TDS3000Reboot.o devCommonGpib.o devSupportGpib.o
boSRQonOff.o drvLinuxGpib.o -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc
-lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc
-lca -lCom -lgpib -lpthread -lreadline -lcurses -lm -lrt -lgcc
/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86/libgpib.a:
file not recognized: File format not recognized
collect2: ld returned 1 exit status
make[2]: *** [libasyn.so] Error 1
make[2]: Leaving directory
`/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/asyn/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/asyn'
make: *** [asyn.install] Error 2
Any ideas??
On 7/16/07, Andrew Johnson <[email protected]> wrote:
Guy Jennings wrote:
> If you look at the .la file with a text editor it should be
> human-readable and
> should contain a line like 'libdir=/usr/lib' which tells where libtool
> thought
> that the real .a (or .so) library was to be installed.
Guy is correct; IIRC the .la file is actually a shell script which
programs that use libtool seem to be able to use instead of a library
somehow before they've been properly installed (it may be that this is
only possible as a shared library). The real libgpib.a (or maybe
libgpib.so) file should be available in a hidden directory inside the
same directory where the .la file is - you'll have to use 'ls -a' to
find that directory though as I don't remember what the naming
convention is that it uses; its name might be mentioned in the .la file
itself too.
- Andrew
> On Jul 16, 2007, at 4:03 PM, Jiro Fujita wrote:
>> I originally installed the driver from National Instrument. Then,
>> when I realized that it appears that Asyn wants to use Linux GPIB
>> package library, according to asynDriver documentation
>> (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-8/asynDriver.html#Linux-gpib),
>> I downloaded linux-gpib-3.2.09, did make and make install.
>> I don't see libgpib.a anywhere on my machine: not in the same
>> directory as libgpib.la nor where I compiled.
>> It appears that at some point, libgpib.a has gotten renamed to
>> libgpib.la in Linux GPIB package library. There has been some
>> references of libgpib.a in older Linux GPIB package library (at least
>> old version, I see a reference of it).
>> I have not tracked down far enough to see where the reference to
>> libgpib.a is made in Asyn (the assumption is that I need to change a
>> few lines somewhere).
>>> Hi,
>>> Jiro Fujita wrote:
>>> > I have been trying to compile Asyn 4-8 with Linux GPIB support. I am
>>> > using a National Instrument PCI GPIB card with EPICS Base 3.14.9 on a
>>> > Scientific Linux 4.2. The card is recognized by the system. I have
>>> > installed linux-gpib-3.2.09.
>>> > When I try to compile Asyn, I get the following error:
>>> > I looked for libgpib.a, but I don't see it on my machine. Instead, I
>>> > find libgpib.la. Does anybody have an idea how to fix this??
>>> I have no experience with your specific problem, but I do know that a
>>> libXXX.la file is usually a version of a library created by an
>>> application that uses GNU libtool before it is installed using 'make
>>> install'.
>>> Did you compile the National Instruments libgpib.la program yourself?
>>> If so, try doing a 'make install' in that directory which in my
>>> experience will cause the appropriate libgpib.a file to be created and
>>> installed in the appropriate location. If you can't do that because you
>>> don't have write access to the target directory you might need to re-run
>>> the ./configure program in the GPIB build area specifying a
>>> --prefix=/path/to/somewhere.
>>> As an alternative, you can try looking for a hidden directory in the
>>> same directory as the libgpib.la file which I think will contain the
>>> actual libgpib.a file that you're looking for.
>>> HTH,
>>> - Andrew
>>> The right to be heard does not automatically include
>>> the right to be taken seriously. -- Hubert H. Humphrey
- RE: Asyn 4.8 compile error with Linux GPIB Mark Rivers
- Asyn 4.8 compile error with Linux GPIB Jiro Fujita
- Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
- Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
- Re: Asyn 4.8 compile error with Linux GPIB Guy Jennings
<2007>
<2007>
