If you look at the .la file with a text editor it should be human-readable and Guy is correct; IIRC the .la file is actually a shell script which programs that use libtool seem to be able to use instead of a library somehow before they've been properly installed (it may be that this is only possible as a shared library). The real libgpib.a (or maybe libgpib.so) file should be available in a hidden directory inside the same directory where the .la file is - you'll have to use 'ls -a' to find that directory though as I don't remember what the naming convention is that it uses; its name might be mentioned in the .la file itself too. - Andrew On Jul 16, 2007, at 4:03 PM, Jiro Fujita wrote: -- The right to be heard does not automatically include the right to be taken seriously. -- Hubert H. Humphrey
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
