1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn 4.8 compile error with Linux GPIB
To: "Jiro Fujita" <[email protected]>, "Andrew Johnson" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Mon, 16 Jul 2007 18:11:18 -0500
> Turns out, libgpib.so is in the same directory as libgpib.la
> (/usr/local/lib).  So, I decided to set LD_LIBRARY_PATH to
> /usr/local/bin.
So it should be looking for /usr/local/lib/libgpib.so
> /home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86/libgpib.a:
> file not recognized: File format not recognized
But instead it is finding
Where did that libgpib.a file come from?  Did you perhaps create it somehow when trying things with the .la file.  Make sure that /home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86/libgpib.a does not exist.
Sent: Mon 7/16/2007 5:55 PM
To: Andrew Johnson; EPICS tech-talk
Subject: Re: Asyn 4.8 compile error with Linux GPIB
After I saw Guy's reply, I took a look at libgpib.la, and he is
correct.  Turns out, libgpib.so is in the same directory as libgpib.la
/usr/local/bin.
This worked as far as the problem I had: I now do get pass libgpib.a
issue.  However, I now get this error:
/usr/bin/ar -rc   libasyn.a      asynManager.o
epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o
drvAsynIPPort.o drvAsynIPServerPort.o asynInt32Base.o
asynInt32SyncIO.o asynInt32ArrayBase.o asynUInt32DigitalBase.o
asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o
asynFloat64ArrayBase.o asynOctetBase.o asynOctetSyncIO.o
asynCommonSyncIO.o asynShellCommands.o asynInterposeEos.o
asynInterposeFlush.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o
devAsynInt32Array.o devAsynUInt32Digital.o devAsynFloat64.o
devAsynFloat64Array.o asynRecord.o drvAsyn.o vxi11core_xdr.o
drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o devCommonGpib.o
devSupportGpib.o boSRQonOff.o drvLinuxGpib.o
/usr/bin/ranlib libasyn.a
Installing library ../../lib/linux-x86/libasyn.a
/usr/bin/ranlib ../../lib/linux-x86/libasyn.a
/usr/bin/g++ -o libasyn.so -shared -fPIC
-L/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86
-L/home/sysuser/epics.3.14.9/base-3.14.9/lib/linux-x86/
-Wl,-rpath,/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/lib/linux-x86
-Wl,-rpath,/home/sysuser/epics.3.14.9/base-3.14.9/lib/linux-x86/
          asynManager.o epicsInterruptibleSyscall.o asynGpib.o
drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o
asynInt32Base.o asynInt32SyncIO.o asynInt32ArrayBase.o
asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o
asynFloat64SyncIO.o asynFloat64ArrayBase.o asynOctetBase.o
asynOctetSyncIO.o asynCommonSyncIO.o asynShellCommands.o
asynInterposeEos.o asynInterposeFlush.o devAsynOctet.o
asynEpicsUtils.o devAsynInt32.o devAsynInt32Array.o
devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat64Array.o
asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o
E2050Reboot.o TDS3000Reboot.o devCommonGpib.o devSupportGpib.o
boSRQonOff.o drvLinuxGpib.o    -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc
-lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc
-lca -lCom -lgpib  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
collect2: ld returned 1 exit status
make[2]: *** [libasyn.so] Error 1
make[2]: Leaving directory
`/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/asyn/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory
`/home/sysuser/epics.3.14.9/modules/soft/asyn4-8g/asyn'
make: *** [asyn.install] Error 2
Any ideas??
On 7/16/07, Andrew Johnson <[email protected]> wrote:
> Guy Jennings wrote:
> > If you look at the .la file with a text editor it should be
> > human-readable and
> > should contain a line like 'libdir=/usr/lib' which tells where libtool
> > thought
> > that the real .a (or .so) library was to be installed.
> Guy is correct; IIRC the .la file is actually a shell script which
> programs that use libtool seem to be able to use instead of a library
> somehow before they've been properly installed (it may be that this is
> only possible as a shared library).  The real libgpib.a (or maybe
> libgpib.so) file should be available in a hidden directory inside the
> same directory where the .la file is - you'll have to use 'ls -a' to
> find that directory though as I don't remember what the naming
> convention is that it uses; its name might be mentioned in the .la file
> itself too.
> - Andrew
> > On Jul 16, 2007, at 4:03 PM, Jiro Fujita wrote:
> >> I originally installed the driver from National Instrument.  Then,
> >> when I realized that it appears that Asyn wants to use Linux GPIB
> >> package library, according to asynDriver documentation
> >> (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-8/asynDriver.html#Linux-gpib),
> >> I downloaded linux-gpib-3.2.09, did make and make install.
> >> I don't see libgpib.a anywhere on my machine: not in the same
> >> directory as libgpib.la nor where I compiled.
> >> It appears that at some point, libgpib.a has gotten renamed to
> >> libgpib.la in Linux GPIB package library.  There has been some
> >> references of libgpib.a in older Linux GPIB package library (at least
> >> old version, I see a reference of it).
> >> I have not tracked down far enough to see where the reference to
> >> libgpib.a is made in Asyn (the assumption is that I need to change a
> >> few lines somewhere).
> >>> Hi,
> >>> Jiro Fujita wrote:
> >>> > I have been trying to compile Asyn 4-8 with Linux GPIB support.  I am
> >>> > using a National Instrument PCI GPIB card with EPICS Base 3.14.9 on a
> >>> > Scientific Linux 4.2.  The card is recognized by the system.  I have
> >>> > installed linux-gpib-3.2.09.
> >>> > When I try to compile Asyn, I get the following error:
> >>> > I looked for libgpib.a, but I don't see it on my machine.  Instead, I
> >>> > find libgpib.la.  Does anybody have an idea how to fix this??
> >>> I have no experience with your specific problem, but I do know that a
> >>> libXXX.la file is usually a version of a library created by an
> >>> application that uses GNU libtool before it is installed using 'make
> >>> install'.
> >>> Did you compile the National Instruments libgpib.la program yourself?
> >>> If so, try doing a 'make install' in that directory which in my
> >>> experience will cause the appropriate libgpib.a file to be created and
> >>> installed in the appropriate location.  If you can't do that because you
> >>> don't have write access to the target directory you might need to re-run
> >>> the ./configure program in the GPIB build area specifying a
> >>> --prefix=/path/to/somewhere.
> >>> As an alternative, you can try looking for a hidden directory in the
> >>> same directory as the libgpib.la file which I think will contain the
> >>> actual libgpib.a file that you're looking for.
> >>> HTH,
> >>> - Andrew
> >>> The right to be heard does not automatically include
> >>> the right to be taken seriously. -- Hubert H. Humphrey
Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Re: Asyn 4.8 compile error with Linux GPIB Andrew Johnson
Re: Asyn 4.8 compile error with Linux GPIB Guy Jennings
Prev: Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Next: Re: Asyn 4.8 compile error with Linux GPIB Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
