Heinrich du Toit wrote:
Hi
Now on one such register for writing I've put a longout record.
As this register will configure the device I want to put in a default
value in the .db file.
so I added the DOL field to the longout register. (this will set the
default VAL of the record and it does)
But when the system initializes the thing goes and READ this register
using the driver. This not only overwrites the default value. It also
gives some garbage as the device can be in unknown state.
As Mark suggests, the driver should handle this register as a special case.
One way the solve the problem is via the st.cmd configuration command
for the driver.
Add an extra argument, which is the initialization value for the
configuration register.
Do the initialization either when the configuration command is executed
or during the first port connect.
Marty
- asyn record support - output Heinrich du Toit
Re: GPIB Ethernet gateway recommendation Rod Nussbaumer
waveform binary init Heinrich du Toit
<2007>
RE: asyn record support - output Mark Rivers
Re: Ethernet/IP Device Support and CompactLogix Mike Forster
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
