Hi
I have an octet device. (asyn driver)
It sends commands to some hardware. Now if I send a certain sequence of
chars to the device I can perform some stuff. e.g. reset the device. Or
set a certain mode. - things that will correspond to buttons on the user
interface.
So I like to setup a waveform record with the necessary data inside as
default. And then only trigger the PROC field so that the data be
written to the device.
My only question is - how do I specify this binary data to the waveform?
for example how do I setup a waveform with CHAR data: 00 01 08 or
something like that?
does the waveform things also read once at start up with asyn? even if
it is a write only command?
thanks
-Heinrich
- Re: waveform binary init Dirk Zimoch
- RE: waveform binary init Mark Rivers
Re: asyn record support - output Marty Kraimer
<2007>
RE: GPIB Ethernet gateway recommendation Pearson, MR (Matthew)
<2007>
