You can set
extraInput = Ignore
and that will discard everything after the bit you are interested in.
It will depend the format of the value part of the message.
If say it was a decimal integer then you could read it
with a protocol:
in "OK:%d,"
or extract the checksum with:
in "OK:%*d,%x"
A variable length string would be more difficult.
Pete
> -----Original Message-----
> From: Phillip Sorensen [mailto:[email protected]]
> Sent: 29 January 2007 17:06
> To: TechTalk EPICS
> Subject: StreamDevice and checksum
> Hello,
> I am trying to get a device working with StreamDevice 2-1. My device
> returns a message in the form of "OK:value,checksum". The
> checksum is
> only for the value part of the message. I am able to skip
> the "OK:" by
> using the width field, but trying to use the precision filed
> to skip the
> "," between the value and checksum gives an error about not
> being able
> to use the precision field.
> Is there a way to tell the parser to skip the ","?
> Phil Sorensen
> CHESS
- RE: StreamDevice and checksum Denison, PN (Peter)
- StreamDevice and checksum Phillip Sorensen
Re: EPICS Base R3.14.9-RC1 Released Andrew Johnson
Re: EPICS Base R3.14.9-RC1 Released Benjamin Franksen
<2007>
<2007>
