1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: StreamDevice and checksum
To: "Phillip Sorensen" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Thu, 1 Feb 2007 00:15:49 -0000
> From: Phillip Sorensen [mailto:[email protected]]
> I am trying to get a device working with StreamDevice 2-1.  My device
> returns a message in the form of "OK:value,checksum".  The checksum is
> only for the value part of the message.  I am able to skip the "OK:" by
> using the width field, but trying to use the precision field to skip the
> "," between the value and checksum gives an error about not being able
> to use the precision field.
> Is there a way to tell the parser to skip the ","?
According to the docs, this should be achievable as you suggest, using:
in "OK:%f,%3.1<xor>"
or whatever value and checksum conversion type you need.
I've looked at the code and can't see why a precision wouldn't work.
What is the error message, exactly?
Have you tried setting streamDebug to 1 (you should be able to do this from the console without rebuilding) and seeing if the copious debugging output helps you to see what's going on?
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton Didcot, Oxon, OX11 0DE
+44 1235 778511
RE: StreamDevice and checksum Phillip A. Sorensen
RE: StreamDevice and checksum Owens, PH (Peter)
Prev: Re: unexpanded macros in comments Andrew Johnson
Next: AAI and AAO Record support David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: StreamDevice and checksum Owens, PH (Peter)
Next: RE: StreamDevice and checksum Phillip A. Sorensen
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
