From the release notes: I don't think this change is as large as you make it. Section 6.20 of the R3.14.8 Application Developers' Guide requires that any filenames containing macros be given in a quoted string, which is a standard behaviour in EPICS DB and DBD files. To allow escaped characters in quoted strings for record field values I had to make some changes to the definition of a quoted string, and when I looked at all the lex and yacc templates in Base I found some horrible coding in dbLoadTemplate - for instance, what self-respecting programmer would regard this as a valid string? "quoted string' MSI won't accept that, but dbLoadTemplate() did. There were a few more horrors like that hidden in the R3.14.8 dbLoadTemplate_lex.l which I just couldn't allow to survive any longer, hence the cleanup. I would be interested to hear of the rationale i.e. what is the great improvement, considering the possible disruption such an incompatible change may cause, and also considering that 3.14.9 has been advertised as a 'mostly bug-fix' release? The syntax allowed by the dbLoadTemplate() command was actually looser than that permitted by MSI, and in places it still is. For example, MSI only permits quoted strings to use a double quote character, whereas dbLoadTemplate() did and still does permit you to use single quotes (but now they do have to match at the two ends of the string). One further issue that I would be interested in is: will the corresponding tool on the host side (MSI) be adapted according to the new rules, so that inflating substitutions on host and target side will remain equivalent? (Or have they ever been after dbLoadTemplate was no longer available on the host side?) The tightening up of the syntax I have done has not affected MSI at all, and I don't intend to make any changes to that tool; the two have probably never been completely identical in the syntax they will accept since they are independently written code, but there is and always will be a core syntax that both understand, which is the syntax described in the Application Developers' Guide. If this change prevents an operational site from upgrading to R3.14.9 I am willing to write a perl script that fixes any files that are no longer accepted by the dbLoadTemplate() command. However I do expect such changes to be minor and probably quicker to fix by hand in most cases - quoting some filenames is likely to be the most common change. - Andrew -- The right to be heard does not automatically include the right to be taken seriously. -- Hubert H. Humphrey
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
