Hello John Sinclair, hello Jianguo Ding,
thank you very much for your help. After adding the lines manually to the file
edmObjects the Objects "Byte", "Textupdate", "RegTextupdate" and "Textentry"
are available, though
edm -show /home/LLRF/EPICS/extensions/lib/linux-386/libPV.so
gives the following output:
Edm component file is /home/LLRF/EPICS/extensions/src/edm/setup/edmObjects
Author name not registered
Library contains no edm components
Thanks
Dorothea Wehler
Quoting Jianguo DING <[email protected]>:
> I added following lines directly to extensions/src/edm/setup/edmObjects to
> avoid this problem.
> TextupdateClass
> /usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so Monitors
> Textupdate
> RegTextupdateClass
> RegTextupdate
> TextentryClass
> /usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so Controls
> Textentry
> ByteClass /usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so
> Monitors Byte
> Jianguo DING
> From: "Dorothea Wehler" <[email protected]>
> To: <[email protected]>
> Sent: Monday, December 04, 2006 10:53 PM
> Subject: libPV.so contains no edm components
> > Hello,
> > I have installed edm-1-11-0s on Fedora Core 4 and SUSE 9.0 (EPICS
> > base-3.14.7). On Fedora Core 4 I had to remove the lines in
> > "fonts.list", which were marked by Dirk Kraemer in his e-mail from
> > 21.11.2006 to avoid a "Segmentation Fault" during startup of the program.
> > Now edm starts without error but on both operating systems there are no
> > edm-components loaded from libPV.so.
> > The command "$EDM -add $EDMBASE/pvFactory/O.$ODIR/libPV.so" in
> > "setup.sh" produces the message: "Library contains no edm components".
> > What might be the reason? The output during installation of the library
> > is attached: "Inst_pvFactory"
> > I`m especially interested in the edm object "Byte".
> > Thanks for any help
> > Dorothea Wehler
- libPV.so contains no edm components Dorothea Wehler
wxPython timer and KEK CaPython314 cause core dump Zhong Ren
<2006>
<2006>
