Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: libPV.so contains no edm components
From: Dorothea Wehler <dorothea.wehler@cryoelectra.de>
To: tech-talk@aps.anl.gov
Date: Mon, 04 Dec 2006 15:53:50 +0100
Hello,
I have installed edm-1-11-0s on Fedora Core 4 and SUSE 9.0 (EPICS base-3.14.7). On Fedora Core 4 I had to remove the lines in "fonts.list", which were marked by Dirk Kraemer in his e-mail from 21.11.2006 to avoid a "Segmentation Fault" during startup of the program.
Now edm starts without error but on both operating systems there are no edm-components loaded from libPV.so.
The command "$EDM -add $EDMBASE/pvFactory/O.$ODIR/libPV.so" in "setup.sh" produces the message: "Library contains no edm components".
What might be the reason? The output during installation of the library is attached: "Inst_pvFactory"
I`m especially interested in the edm object "Byte".
Thanks for any help
Dorothea Wehler
make -C pvFactory install
make[1]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory'
perl /home/LLRF/EPICS/base-3.14.7/configure/tools/makeMakefile.pl O.linux-x86 ../../../..
perl /home/LLRF/EPICS/base-3.14.7/configure/tools/makeMakefile.pl O.linux-386 ../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-x86'
make[2]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../textupdate.cc
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../SciPlot.c
../SciPlot.c: In function ¡ÆDrawAll¡Ç:
../SciPlot.c:3286: warning: ¡Æy1¡Ç may be used uninitialized in this function
../SciPlot.c:3286: warning: ¡Æx1¡Ç may be used uninitialized in this function
../SciPlot.c:3415: warning: ¡Æx1¡Ç may be used uninitialized in this function
../SciPlot.c:3415: warning: ¡Æy1¡Ç may be used uninitialized in this function
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../strip_data.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../strip.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../regTextupdate.cc
../textupdate.h:28: warning: ¡Ævoid drag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined
../textupdate.h:30: warning: ¡Ævoid selectDrag(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined
../textupdate.h:32: warning: ¡Ævoid selectActions(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined
../textupdate.h:34: warning: ¡Ævoid pvInfo(_WidgetRec*, XEvent*, char**, Cardinal)¡Ç declared ¡Æstatic¡Ç but never defined
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../byte.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1      -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../pv_register.cc
/usr/bin/ar -rc   libPV.a       textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o
/usr/bin/ranlib libPV.a
Installing library ../../../../lib/linux-x86/libPV.a
/usr/bin/ranlib ../../../../lib/linux-x86/libPV.a
/usr/bin/g++ -o libPV.so -shared -fPIC      -L../../../../lib/linux-x86      -Wl,-rpath,/home/LLRF/EPICS/extensions/lib/linux-x86 -Wl,-rpath,/home/LLRF/EPICS/base-3.14.7/lib/linux-x86         textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o     -lpthread   -lreadline -lcurses -lm -lrt
Installing shared library ../../../../lib/linux-x86/libPV.so
make -C O.linux-386 -f ../Makefile TOP=../../../.. T_A=linux-386 install
make[2]: Entering directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-386'
make[2]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory/O.linux-386'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../textupdate.cc
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../SciPlot.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../strip_data.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../strip.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../regTextupdate.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../byte.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSINGLE_THREADED=1 -D__epics__=1 -march=i386     -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include -I/home/LLRF/EPICS/base-3.14.7/include/os/Linux -I/home/LLRF/EPICS/base-3.14.7/include    -I../ -I../../../../include/edm -I../../util -I../../pvlib -I../../lib    ../pv_register.cc
Installing library ../../../../lib/linux-386/libPV.a
/usr/bin/ranlib ../../../../lib/linux-386/libPV.a
/usr/bin/g++ -o libPV.so -shared -fPIC      -L../../../../lib/linux-386      -Wl,-rpath,/home/LLRF/EPICS/extensions/lib/linux-386 -Wl,-rpath,/home/LLRF/EPICS/base-3.14.7/lib/linux-386         textupdate.o SciPlot.o strip_data.o strip.o regTextupdate.o byte.o pv_register.o     -lpthread   -lreadline -lcurses -lm -lrt
Installing shared library ../../../../lib/linux-386/libPV.so
make[1]: Leaving directory `/home/LLRF/EPICS/extensions/src/edm/pvFactory'
Prev: RE: CA gateway question Jeff Hill
Next: Re: libPV.so contains no edm components Dorothea Wehler
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: EDM X-Y graph rescaling Chestnut, Ronald P.
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
