I managed to isolate a core dump in a minimized Python code
(see below). I found two components are essential to cause a
core dump: wx.Timer and ca.Monitor (or ca.Get). Can someone
tell what the problem is?
import wx
import ca
def onTimer(event): pass
ca.Monitor('S:SRcurrentAI')
appli = wx.PySimpleApp()
frame = wx.Frame(None)
timer = wx.Timer()
timer.Bind(wx.EVT_TIMER, onTimer)
timer.Start(milliseconds = 10, oneShot = False)
appli.MainLoop()
Other info:
Pyhton 2.5
wxPython 2.6.3.3
RedHat Linux x86_64
GCC 4.1.1
To test, let the routine run for a while. A core dump will
occur in a few minutes.
- Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Re: libPV.so contains no edm components Dorothea Wehler
wxPython timer and KEK CaPython314 cause core dump Matt Newville
<2006>
<2006>
