1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: ezca and ENUM
To: "D. Peter Siddons" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: <[email protected]>
Date: Thu, 24 Aug 2006 11:23:27 -0500
Hi Pete,
Have you taken a look at the wrappers in ezcaIDL.c?  In addition to
wrappers around all of the ezca functions I added a couple of additional
ones
ezcaIDLGetCountAndType
ezcaIDLGetEnumStrings
I am appending the documentation for the IDL procedure caGetCountAndType
which works around the enum restriction you have encountered, and also
for caGetEnumStrings.
Cheers,
function caGetCountAndType, pvname, count, type
; NAME:
;       caGetCountAndType
; PURPOSE:
;       This function returns the number of elements and data type of a
;       Channel Access process variable.
; CATEGORY:
;       EPICS Channel Access Interface
; CALLING SEQUENCE:
;       Status = caGetCountAndType(pvname, count, type)
; INPUTS:
;       pvname: The name of the process variable for which information
is to
;               be returned.
; OUTPUTS:
;       count:  The number of elements in the process variable. This is
1 for
;               scalar process variables and more than 1 for arrays.
;       type:   This is a 3 element array containing information about
the data
;               type of the process variable.
;               type(0) = Channel access data type as defined in
"cadef.h"
;               type(1) = EZCA data type as defined in "ezca.h"
;               type(2) = IDL/PV-WAVE data type as defined in size()
;               These data types are as follows:
;               Name    Channel Access      EZCA        IDL/PVWAVE
;               String      0                 1             7
;               Short       1                 2             2
;               Float       2                 4             4
;               Enum        3                 2 (short)     2 (short)
;               Byte        4                 0             1
;               Long        5                 3             3
;               Double      6                 5             5
;   The function return value of caGetCountAndType is a status value.
The
;   status is 0 if the routine was successful (i.e. the process variable
exists)
;   and non-zero if the routine failed.
; SIDE EFFECTS:
;       This routine will cause a Channel Access search to take place if
this is
;       the first time this process variable has been referenced.
; RESTRICTIONS:
;       The channel access data type enum is mapped to EZCA and IDL
short
;       data types.  However, application programs can use this routine
to
;       determine if the native channel access data type is enum, and
then
;       use caGet(pvname, value, /string) to read the string equivalent
of the
;       process variable. Programs can also use
;       caGetEnumStrings(pvname, strings) to read the strings for the
all of
;       the possible values of an enum process variable.
; PROCEDURE:
;       This routine uses ezcaPvToChid() and then ca_element_count() and
;       ca_field_type().
;       Note that this routine always returns its values "immediately",
even
;       if it is called between a caStartGroup and caEndGroup.
; EXAMPLE:
;       IDL> status = caGetCountAndType('test_mca1.VAL', count, type)
;       IDL> print, status
;       0                       ; Status = success
;       IDL> print, count
;       2048                    ; Array with 2048 elements
;       IDL> print, type
;           5       3       3   ; Long data type
; MODIFICATION HISTORY:
;       Written by:     Mark Rivers
;       June 28, 1995
function caGetEnumStrings, pvname, strings
; NAME:
;       caGetEnumStrings
; PURPOSE:
;       This function returns all of the choice strings associated with
a
;       Channel Access "enum" process variable. It is particularly
useful
;       for building menus of options.
; CATEGORY:
; CALLING SEQUENCE:
;       Status = caGetEnumStrings(pvname, strings)
; INPUTS:
;       pvname: The name of the process variable for which the enum
strings
;               are to be returned. The native channel access data type
of
;               this process variable must be enum (3).
; OUTPUTS:
;       strings: A string array containing the strings for each possible
;               value of the enum variable.
;       The function return value of caGetEnumStrings is a status value.
The
variable
;       exists and is of type enum) and non-zero if the routine failed.
; SIDE EFFECTS:
;       This routine causes a channel access read. It does not use the
;       grouping mechanism of EZCA, i.e. it always executes immediately.
; RESTRICTIONS:
;       There must be less than MAX_ENUM_STATES enum strings and they
must each be
;       less than MAX_STRING_SIZE characters.
; PROCEDURE:
;       This routine uses ezcaPvToChid and then ca_get() with a request
type
;       of DBR_GR_ENUM.  The functionality required by this routine is
not
;       presently provided directly in EZCA, although it should probably
be
;       added.
; EXAMPLES:
;       IDL> status = caGetEnumStrings('test_mca1.SCAN', strings)
;       IDL> for i=0, n_elements(strings)-1 do print, strings(i)
;       Passive
;       Event
;       I/O Intr
;       10 second
;       5 second
;       2 second
;       1 second
;       .5 second
;       .2 second
;       .1 second
;       June 28, 1995
> -----Original Message-----
> From: D. Peter Siddons [mailto:[email protected]]
> Sent: Thursday, August 24, 2006 10:24 AM
> To: Andrew Johnson
> Cc: [email protected]
> Subject: Re: ezca and ENUM
> Hi Andrew,
>    Yes, a string would work as well, but I was writing the Octave
> wrappers for ezca which I'd like to make self-contained and general.
> This implies asking the record what type it is in order to make calls
> with the correct type. It would be nice if valid types were
> treated as
> such by the library :) As it is, I trap the ENUM type in my
> wrapper and
> turn it into a SHORT, and all is well. But it hides what I
> feel is a bug.
> Pete.
> Andrew Johnson wrote:
> > D. Peter Siddons wrote:
> >> I noticed that the ezca library does not recognize ENUM as a valid
> >> data type. One can work around that by telling it to use a SHORT
> >> instead. If
> > Would it help to use string data for doing I/O to DBF_ENUM
> fields?  That
> > way you don't need to know the exact ENUM definition (which
> could change
> > at runtime even for mbbx.VAL fields); your code just uses
> the strings
> > for the states that you need to use, and the IOC does the necessary
> > conversions automatically.
> > Just an idea,
> > - Andrew
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ezca and ENUM D. Peter Siddons
Next: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" David Dudley
