1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ezca and ENUM
Cc: [email protected]
Date: Thu, 24 Aug 2006 11:24:20 -0400
Hi Andrew,
Yes, a string would work as well, but I was writing the Octave wrappers for ezca which I'd like to make self-contained and general. This implies asking the record what type it is in order to make calls with the correct type. It would be nice if valid types were treated as such by the library :) As it is, I trap the ENUM type in my wrapper and turn it into a SHORT, and all is well. But it hides what I feel is a bug.
Pete.
Andrew Johnson wrote:
D. Peter Siddons wrote:
I noticed that the ezca library does not recognize ENUM as a valid data type. One can work around that by telling it to use a SHORT instead. If
Would it help to use string data for doing I/O to DBF_ENUM fields? That way you don't need to know the exact ENUM definition (which could change at runtime even for mbbx.VAL fields); your code just uses the strings for the states that you need to use, and the IOC does the necessary conversions automatically.
Just an idea,
- Andrew
ezca and ENUM D. Peter Siddons
Re: ezca and ENUM Andrew Johnson
Prev: Re: ezca and ENUM Andrew Johnson
Next: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: ezca and ENUM Mark Rivers
