1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VME Bus Error handling on MVME3100 and 6100 boards
To: Kate Feng <[email protected]>
Cc: Till Straumann <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 24 Aug 2006 11:11:37 -0500
Kate Feng wrote:
Discovery deos not have the necessary capability or connections to the MCP. I was told that
on the boards which use a Discovery system controller, the MCP signal is connected to a
pull-up and therefore not used as it is on other boards. That's the design on the
MVME5500 and MVME6100 boards. I do not see it as a big problem for the
MVME5500 board because ......
Till Straumann wrote :
(currently, a PCI error such as target abort is routed to the one
and only EE interrupt of the powerpc).
The MCP, if available, is routed to the EE interrupt as well.
I personally would see it as a problem, because the EE interrupt is maskable. It's not trivial to write an exception handler that can nest properly such that if an interrupt service routine receives a Target- Abort from a PCI device it will immediately halt and abort the ISR rather than continuing on to completion and only then running the Target-Abort interrupt handler. If all you have is an interrupt, your ISRs probably ought to check with the Tempe chip that they're not getting VME bus errors before relying on the data they've just read (at least if the value they read back was all-1s).
For the MVME6100, I am more concerned with the
"making use of the dud all-1's read data in the process"
that Andrew mentioned earlier. I do'nt seem to get the answer from the
http://www.aps.anl.gov/epics/tech-talk/2006/msg00892.php, which was posted by Till.
Is it in the "vmeTsi148ClearVMEBusErrors(&erraddr);" ? How is it programmed?
I'm not sure I understand your question. The "all-1s read data" I was talking about is the data that is returned if you do a programmed read cycle to the VMEbus that ends in a Bus Error. If the Bus Error occurs during a DMA operation using one of the DMA controllers in the Tempe chip then the DMA will be stopped immediately instead, since the controller is inside the Tempe and can see the Bus Error status.
We have one application that could be optimied by the PCI  bandwidth
that MVME61000 offers ( 800 MHZ).
Also, I am still not sure about the  "MBLT" transfer of
the VME backplane, whih was posted at
http://www.aps.anl.gov/epics/tech-talk/2006/msg00888.php.
I assumed it was limited by the capability of the DMA controller
instead of the bus speed because I assume a simple test could be done
easily by using two MVME6100s on a VME320 crate.  Perhaps
Till can verify this ??
The Tempe's DMA controllers are most likely to be limited by the speed of the VMEbus when doing MBLT cycles; the maximum data transfer rate you can get using MBLT is 80MB/s according to the VITA FAQ at http://www.vita.com/vmefaq.html#anchor419155 whereas the PCI/X bus on the MVME6100 can run faster than that. If you have a VME320 backplane and both boards are capable of 2eSST then your bottleneck might not be the VMEbus, but I don't know the answer to that question.
Andrew Johnson wrote:
 > Anyone interested in MicroTCA to replace the now aging VMEbus?
Why do you think VMEbus is aging ?  I was researching the VXS bus for
a short while and comapred it with  the MVME6100 solution for our
application.  VMEbus does not seem to be aging for me.
The VMEbus was first announced in 1981 - that's 25 years ago, which is what makes it aging as far as basic technology goes. I'm not saying its not still capable of doing the job, but the basic assumptions that the bus was designed around are starting to be seriously invalidated and for new facilities such as the ILC I would carefully examine alternative busses such as MicroTCA.
- Andrew
There is considerable overlap between the intelligence
of the smartest bears and the dumbest tourists.
  -- Yosemite National Park Ranger
Re: VME Bus Error handling on MVME3100 and 6100 boards Korhonen Timo
Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Re: VME Bus Error handling on MVME3100 and 6100 boards Andrew Johnson
Prev: RE: NetBSD: implementation of"osiSockDiscoverInterfaceAddresses()" Jeff Hill
Next: RE: ezca and ENUM Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VME Bus Error handling on MVME3100 and 6100 boards Kate Feng
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Korhonen Timo
