1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Can I use the DISA field for user data?
To: [email protected]
Date: Fri, 14 Jul 2006 10:35:46 -1000
Ned Arnold wrote:
Harley,
If the DISA field gets set such that it equals the DISV field, the AI record will become "disabled" anytime (which means that the record processing routine will not execute).
Some options:
- If you set DISA to 2 and 3 for "yes" and "no", then it will never equal the default value of DISV (which is 1) and you won't interfere with anything.
- If the AI record is not scanned via EVENT, the EVNT field is not used.
- Unused LOW, LOLO, HIGH, HIHI fields could be used
just to add: as well as their related severity fields, HSV, HHSV, LSV and LLSV.
Maren
- The SIOL field is also available if you don't use simulation mode.
Hope this helps -
"A fellow pragmatic"
Harley N wrote:
This should be a quick and simple question.  I am using AI records to
store data that goes from equipment to a Java GUI.  I need to add a
boolean "disable" field to hide things on the GUI, but still have
them get put into Epics.  Does the "DISA" field have any special
meaning that will affect the CA server, or can I use it for my own
purposes?
Harley
Harley Nelson Software Engineer Echostar Communications LLC
_________________________________ SISNA...more service, less money. http://www.sisna.com/exclusive/
Can I use the DISA field for user data? Harley N
Re: Can I use the DISA field for user data? Ned Arnold
Prev: Re: Can I use the DISA field for user data? Ned Arnold
Next: RE: Can I use the DISA field for user data? Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
