Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: adding a scan period
From: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
To: Andrew Johnson <anj@aps.anl.gov>
Cc: john sinclair <sinclair@mail.phy.ornl.gov>, tech talk <tech-talk@aps.anl.gov>
Date: Wed, 05 Apr 2006 10:48:43 -0700
John,
Create you own menuScan.dbd in your ${MY_DIRECTORY}/dbd directory.
Then edit the makefile in your driver source and add a new USR_DBDFLAGS
directive.
# Used by dbExpand to look for dbd files
USR_DBDFLAGS += -I ${MY_DIRECTORY}/dbd
USR_DBDFLAGS += -I ${EPICS_BASE}/dbd
Note that the order of the directories is important.
Emmanuel
On Wed, 2006-04-05 at 11:25 -0500, Andrew Johnson wrote:
> john sinclair wrote:
> > What's the correct file to edit to add a scan period. I have narrowed things
> > down to the following two:
> > ...base/dbd/menuScan.dbd
> > ...base/src/db/menuScan.dbd
> The base/dbd directory is the install location where the file from
> src/db gets installed to, so you don't want to edit anything inside
> base/dbd or your changes will be lost when you next rebuild base.
> Note however that you can also override the scan periods in an IOC
> application by just providing your own modified copy of menuScan.dbd,
> which will be found before the base one.
> - Andrew
Emmanuel Mayssat
Cell: 650/793-0626
Lyncean Technologies, Inc.
"See the invisible"
Re: adding a scan period Andrew Johnson
adding a scan period john sinclair
Prev: Re: adding a scan period Andrew Johnson
Next: Re: adding a scan period Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
