John, Create you own menuScan.dbd in your ${MY_DIRECTORY}/dbd directory. Then edit the makefile in your driver source and add a new USR_DBDFLAGS directive. Actually you don't even need to do this, just add this line to your xxxApp/src/Makefile in the directory where you put the modified menuScan.dbd file: DBD += menuScan.dbd This will ensure that the file gets installed to $(TOP)/dbd. In the DBD file expansion process the directory $(TOP)/dbd is always searched before $(EPICS_BASE)/dbd so it will find your version first. Make sure that you do a 'make rebuild' after adding that line though. - Andrew -- There is no S in exprexxo.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
