1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: adding a scan period
To: john sinclair <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 05 Apr 2006 11:25:12 -0500
john sinclair wrote:
What's the correct file to edit to add a scan period. I have narrowed things down to the following two:
...base/dbd/menuScan.dbd
...base/src/db/menuScan.dbd
The base/dbd directory is the install location where the file from src/db gets installed to, so you don't want to edit anything inside base/dbd or your changes will be lost when you next rebuild base.
Note however that you can also override the scan periods in an IOC application by just providing your own modified copy of menuScan.dbd, which will be found before the base one.
- Andrew
There is no S in exprexxo.
Re: adding a scan period Emmanuel Mayssat
adding a scan period john sinclair
Prev: adding a scan period john sinclair
Next: Re: adding a scan period Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
