Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Variable scan rate
From: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
To: Steven Hartman <hartman@fel.duke.edu>
Cc: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Thu, 05 Jan 2006 10:53:20 -0800
There are several cases in which I may want to slow down ( and even
stop ) scan rates.
1/ debugging purpose
	Debugging messages are displayed each time the record
	is processed. When my Ioc crashes I do not want to be flooded
	with debugging information. Ultimately I want to see only the
	debug info of the record that crashed the ioc.
2/ overload of an ioc
	I want to put as many devices on an ioc as possible
	so I need to minimize record processing.
	That is one way to improve uptime and lower cost
	of control system
3/ Bus conflict
	There are also bus conflict I want to minimize
	(several devices on same gpib bus, etc. )
4/ temperature can be read by another more accurate device
5/ temperature cannot change due to external factors. Granted that
regulation may fail due to a failure of the regulating device itself, in
that case we have a device alarm that trip.
The thermo regulator device I was referring to complies with all of the
above.
Anyway what is interesting to me at this point is to change scan rate
from high to low. I want to see the readback transition at high
resolution and slow the scan rate once everything stabilize.
I like the NPP & PP trick in the calcout.
The sequencer is also a great solution.
Now I can pick between a value based versus a time based solution.
Many thanks for your input,
Emmanuel Mayssat
On Thu, 2006-01-05 at 12:37 -0500, Steven Hartman wrote:
> be set by the operator using an MEDM "menu" button. But for something like
> the temperature readback, I would just leave it at the fast rate all of
> the time.
Re: Variable scan rate Steven Hartman
Building JCA1 John Faucett
Variable scan rate Emmanuel Mayssat
Prev: Re: Building JCA1 Janet Anderson
Next: Re: Variable scan rate Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Variable scan rate Maren Purves
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
