Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Variable scan rate
To: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
Cc: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Thu, 5 Jan 2006 12:37:49 -0500 (EST)
On Thu, 5 Jan 2006, Emmanuel Mayssat wrote:
> The record starts in passive mode When I change the temperature
> settings, the record should have a high scan rate. When the readback
> stabilizes, the scan rate should decrease and after some amout of time
> go back to passive.
The SCAN field can be modified at runtime. You can have some routine do a
put into this field, or perhaps do it within the database using a calc and
an mbbo or a calcout. I have a couple of records where the SCAN rate can
be set by the operator using an MEDM "menu" button. But for something like
the temperature readback, I would just leave it at the fast rate all of
the time.
Steve Hartman
hartman@fel.duke.edu || 919-660-2650
Duke Free Electron Laser Laboratory
Re: Variable scan rate Maren Purves
Re: Variable scan rate Emmanuel Mayssat
Building JCA1 John Faucett
Prev: RE: Variable scan rate Dalesio, Leo `Bob`
Next: Re: Variable scan rate Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Variable scan rate Emmanuel Mayssat
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
