1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Using subArray
To: "Abbott, MG (Michael)" <[email protected]>
Cc: [email protected]
Date: Mon, 28 Nov 2005 21:01:06 +0900
Abbott, MG (Michael) wrote:
Noboru Yamamoto wrote:
Michael Abbott wrote:
I am writing device support for a subArray record so that I can read
small slices from a very large array provided by a device.
We had similar problem when we tarted to construct KEKB control system. So we developed a new record called Compact Subarray record. It just copys amount it needs from a source record. We need to add new API in dbaccess library, which is not present in the standard EPICS base, to support this record.
If you have an interest on this record, I will be happy to send source code.
Thank you for the thought.  I'll see if I can make things work with
subArray first.  If I have problems I'll be in touch!
I'd prefer to use the standard record type (even if I am milding
abusing it) if I can.  You say also that your Compact Subarray
"copies amount it needs from a source record" -- do you mean that the
source has to be another Epics record, or can it be purely device
data?
Currently it just have SoftDevice support. In priciple, you can use write device support for this record.
Noboru
RE: Using subArray Abbott, MG (Michael)
Prev: Re: environmental variables Ralph Lange
Next: Re: EDM on Windows + Hummingbird? Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Using subArray Abbott, MG (Michael)
Next: environmental variables Xu HuiJuan
