1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: GpibCore generates "broken pipe"
To: Eric Williams <[email protected]>
Cc: [email protected]
Date: Fri, 17 Sep 2004 06:44:56 -0500
Since asynDriver is the sucessor to gpibCore, gpibCore is no longer supported. See
http://www.aps.anl.gov/epics/modules/soft/asyn
Marty Kraimer
Eric Williams wrote:
OK, figured it out. The Reboot has to be called before the Config. The documentation file has the calls in the wrong order, this should be fixed.
eric
I'm trying to talk to a Agilent E2050B using GpibCore 1-1 under EPICS 3.14.2 running on RedHat Linux Enterprise. During startup, I get the following sequence:
drvVxi11Config(0, "tsp-gpibdev.als.lbl.gov", 0, 0, "hpib", 0)
drvVxi11 (release 1.0) initialized successfully
E2050Reboot("tsp-gpibdev.als.lbl.gov")
drvVxi11 (release 1.0) initialized link 0
epicsThreadCreate vxiReconnect
Broken pipe
Followed by the IOC aborting to shell. The target GPIB interface does seem to indicate with blinking lights that it got reset.
Anybody run into this before that can tell me what's I'm doing wrong? Thanks!
Eric Williams
ALS Controls, LBL
GpibCore generates "broken pipe" Eric Williams
Re: GpibCore generates "broken pipe" Eric Williams
Prev: Understand the EPICS fdmgr functions Andy Foster
Next: RE: ca_repeater bug (probably observable only on RTEMS) Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Xycom 9660 wtw00992
Next: Re: Xycom 9660 Andy Foster
