1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Xycom 9660
To: Epics Questions <[email protected]>
Date: Fri, 17 Sep 2004 11:28:35 +0100 (BST)
Hi Bill,
I haven't used the Xycom 9660 with a TIP-810 myself so it's
difficult for me to diagnose the problem.
I'll send you a newer version of the Xycom 9660 code which has
been modified for use with RTEMS under 3.14 by Stephanie Allison at SLAC.
It should also work under vxWorks. Please give that a go.
Do you know if the code is hanging in the 9660 driver or in the
TIP-810 driver or device support? Does the TIP-810 use interrupts,
if so, that might be a place to look?
If you are getting through the calls to:
ipacAddCarrier &xy9660, "<base addr>"
and the "create" call for the TIP-810 I guess you are,
at least, finding the card at your base address.
I think the way I'd debug this is by putting in some printf's in
the Xycom-9660/TIP-810 driver and TIP-810 device support functions
and see where it gets to before hanging.
I'll be interested to hear what you find!
Cheers,
Andy
On Fri, 17 Sep 2004, wtw00992 wrote:
> Greetings (from sleepless in L.I.)
> I am trying to use a TIP-810 with a Xycom 9660.  I followed the instructions
> from Andy Fosters site at OSL..
> Things looked ok when I did my make but the processor hung up at
> intitialization..
> I didnt copy all of the files drvIpac.dbd files  and header files from the
> xycom-1.0 dir over to  drvIpac, as  they seem to be older versions that what
> I have in my drvIpac <support top>,  I did a diff and didnt see any
> differences in the .dbd, but saw some in one of the header files...
> I was wondering if  there was an update to the xycom 9660 files.. or perhaps
> a better way to do this.. by making a completely separate <support top> for
> the xycom.
> I am presupposing that some body out there has used the TIP810 with this
> board... one of our subsytems purchased it and I would like to get it to
> work, eventually with both a TIP 810 and an IP-OCTAL 232.. but certainly
> with the TIP 810.
> Thanks in advance for your comments.
> Bill Waggoner
> STAR
> BNL/Upton NY
> or
> Creighton Univ/Omaha NE
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Prev: Xycom 9660 wtw00992
Next: Understand the EPICS fdmgr functions Andy Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: GpibCore generates "broken pipe" Marty Kraimer
Next: RE: Xycom 9660 Allison, Stephanie
