1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: modtcp channel status
To: [email protected]
Date: Thu, 18 Mar 2004 11:18:36 -0800
We recently hooked up some Wago modules here to monitor some thermocouples through ethernet connections. Since we were dealing with several isolated monitoring locations, one of the things I wanted in the driver was the ability to make sure the ethernet connection was intact through the EPICS channel status. We're using the DESY modification of the TRIUMF modtcp driver (http://www-kryo.desy.de/documents/EPICS/DESY/Records/wagoModbusSup.html), and the driver did not show any change of status with a break in the TCP/IP connection, but some of the code appeared to show that the basic mechanism was already there. Fiddling around with the code a bit, I came up with this mod:
In modtcpRead(), change the line:
if (pPlc->pSock->tcpsFd == INVALID_SOCKET) return -1;
to:
if (pPlc->pSock->connecting || pPlc->pSock->tcpsFd == INVALID_SOCKET) return -1;
Similarly change modtcpWrite(). The timeouts are long, but the record status does eventually go INVALID when the connection is lost, and then recovers when it is reestablished.
Eric Williams
ALS Controls
Lawrence Berkeley Lab
Prev: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
Next: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: et_wish mon problem Lei Ge
Next: modbus+ Terry Carlino
