1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: et_wish mon problem
To: EPICS tech-talk <[email protected]>
Date: Tue, 30 Mar 2004 16:07:40 +0800 (CST)
Dear all,
A friend suggested me to change "pv link" to "pv linkw".
Then it works.
Sorry for the disturbing.
Ge
On Tue, 30 Mar 2004, Lei Ge wrote:
> Dear all,
> I'm using et_wish to monitor the changes of a PV. I wrote a simple
> application as:
> label .l -text "local/remote"
> pack .l
> pv link monL leige:local
> pv mon monL {.l config -text "changed"}
> If I type the above commands line by
> line interactively in et_wish, it works, e.g. when the PV changed, the
> label on this application can be changed.
> The problem is that if I put these lines in a file and run "et_wish
> the-file-name", the PV is not monitored. Nothing happens. In et_wish,
> source the file does not work, either.
> Did I miss something? Any suggestion is appreciated.
> I'm using EPICS 3.13.8 on Solaris.
> Thank you,
> Ge
et_wish mon problem Lei Ge
Prev: et_wish mon problem Lei Ge
Next: ezcaIDL ELF class error Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: modtcp channel status Eric Williams
