1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA error
To: "'john sinclair'" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Tue, 29 Oct 2002 19:30:59 -0700
John,
Do you check the status from ca_get_callback() when you call it?
It's possible to get ECA_DISCONN back as status if the connection
is down at the instant that ca_get_callback() is called. You will
also see ECA_DISCONN in the status field of event_handler_args if
the virtual circuit disconnects sometime after the get callback
request is made, but before the response arrives from the server.
If you think that your situation is occurring in a situation that is
not related to disconnects then I will need to research this in
more detail.
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Tuesday, October 29, 2002 11:23 AM
> To: Jeff Hill
> Cc: 'tech talk'
> My mistake, the error is ECA_DISCONN (which makes more sense)
> and not ECA_ANACHRONISM (I shifted the value twice instead
> of 3 times).
> And, no, I'm not calling CA from a multi-threaded application.
> John
> On Tue, 29 Oct 2002, Jeff Hill wrote:
> > John,
> > >   examine args.status
> > >   // status here is sometimes ECA_ANACHRONISM
> > > Has this always been possible?
> > I think you are asking if CA will set the status
> > field in the event_handler_args structure to
> > ECA_ANACHRONISM. The answer is no. I searched
> > all of the source code in the latest versions of
> > R3.13 and R3.14 and ECA_ANACHRONISM is returned
> > only when you call a very old CA interface from
> > R3.11 or probably earlier that is no-longer
> > supported.
> > Are you calling CA from a multi-threaded
> > application?
> > Jeff
> > > Sent: Tuesday, October 29, 2002 10:48 AM
> > > To: tech talk
> > > Subject: CA error
> > > One stress test I have applied to edm is performing a moderately
> rapid
> > > succession of connects/disconnects via a channel access server.
> > > I have recently noticed one problem.
> > > The logical code structure is shown below:
> > > global needInit
> > > main routine:
> > > needInit = false
> > > search_and_connect
> > > do {
> > >   pend io, event
> > >   if ( needInit ) {  // needInit is set in the connect callback
> > >     ca_get_callback(...)
> > >     needInit = false
> > > } until all outstanding io is complete
> > > connect_callback function (...) {
> > >   if ( pv is connected ) {
> > >     needInit = true
> > >   else {
> > >     needInit = false
> > > get_callback function (
> > >   struct event_handler_args args
> > >   examine args.status
> > >   // and args.dbr is NULL
> > > Has this always been possible? I'm sure I get the connect callback
> > > before
> > > the get callback (by examining other data that gets set in the
> connect
> > > callback {not shown in above simplified example}).
> > > John Sinclair
> > > [email protected]
> > > Oak Ridge National Lab
> > > 865-576-6362   865-574-1268 (fax)
> John Sinclair
> [email protected]
RE: CA error john sinclair
Prev: RE: Simatic PLCs Robby Tanner
Next: RE: CA error john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: CA error john sinclair
