Jeff,
I think everything is OK. I see that this is clearly the best way
to do things from a performance perspective. I naively assumed that I
would get all the get-callbacks based on a previous state. I also naively
assumed that I wouldn't get event callbacks between disconnects and
reconnects. Back to the drawing board...
John
On Tue, 29 Oct 2002, Jeff Hill wrote:
> John,
> Do you check the status from ca_get_callback() when you call it?
> It's possible to get ECA_DISCONN back as status if the connection
> is down at the instant that ca_get_callback() is called. You will
> also see ECA_DISCONN in the status field of event_handler_args if
> the virtual circuit disconnects sometime after the get callback
> request is made, but before the response arrives from the server.
> If you think that your situation is occurring in a situation that is
> not related to disconnects then I will need to research this in
> more detail.
> Jeff
> > -----Original Message-----
> > From: john sinclair [mailto:[email protected]]
> > Sent: Tuesday, October 29, 2002 11:23 AM
> > To: Jeff Hill
> > Cc: 'tech talk'
> > Subject: RE: CA error
> > My mistake, the error is ECA_DISCONN (which makes more sense)
> > and not ECA_ANACHRONISM (I shifted the value twice instead
> > of 3 times).
> > And, no, I'm not calling CA from a multi-threaded application.
> > John
> > > John,
> > > > examine args.status
> > > > // status here is sometimes ECA_ANACHRONISM
> > > > Has this always been possible?
> > > I think you are asking if CA will set the status
> > > field in the event_handler_args structure to
> > > ECA_ANACHRONISM. The answer is no. I searched
> > > all of the source code in the latest versions of
> > > R3.13 and R3.14 and ECA_ANACHRONISM is returned
> > > only when you call a very old CA interface from
> > > R3.11 or probably earlier that is no-longer
> > > supported.
> > > Are you calling CA from a multi-threaded
> > > application?
> > > Jeff
> > > > Sent: Tuesday, October 29, 2002 10:48 AM
> > > > To: tech talk
> > > > Subject: CA error
> > > > One stress test I have applied to edm is performing a moderately
> > rapid
> > > > succession of connects/disconnects via a channel access server.
> > > > I have recently noticed one problem.
> > > > The logical code structure is shown below:
> > > > global needInit
> > > > main routine:
> > > > needInit = false
> > > > search_and_connect
> > > > do {
> > > > pend io, event
> > > > if ( needInit ) { // needInit is set in the connect callback
> > > > ca_get_callback(...)
> > > > needInit = false
> > > > } until all outstanding io is complete
> > > > connect_callback function (...) {
> > > > if ( pv is connected ) {
> > > > needInit = true
> > > > else {
> > > > needInit = false
> > > > get_callback function (
> > > > struct event_handler_args args
> > > > examine args.status
> > > > // and args.dbr is NULL
> > > > Has this always been possible? I'm sure I get the connect callback
> > > > before
> > > > the get callback (by examining other data that gets set in the
> > connect
> > > > callback {not shown in above simplified example}).
> > > > John Sinclair
> > > > [email protected]
> > > > Oak Ridge National Lab
> > > > 865-576-6362 865-574-1268 (fax)
> > John Sinclair
> > [email protected]
John Sinclair
[email protected]
- RE: CA error Jeff Hill
EPICS Meeting Agenda Karen White
<2002>
<2002>
