> - can I upgrade just this record, or does it need new features of
> this release ?
mbboDirect.c is unchanged, only the .dbd has been changed. So replacing
the dbd and running a "make" in src/rec to install it should do the job.
You won't even have to rebuild any other parts of base, but you will
have to re-generate the dbd file that your IOC loads and reboot the IOC
to make the change work.
> - is there another way to write a value to this record so that it
> sets all its outputs at the same time ?
No. (Well, at least not by using Channel Access...)
> If this did not work before - ( and it has been around a few years)
> I can't understand what was the use of this record ?
mbboDirect is used (~520 times in our installation) to combine single
command bits into a status word:
command1 (bo) OUT --PP-NMS--> B0
command2 (bo) OUT --PP-NMS--> B1 commandWord (mbboDirect) OUT ---> Hardware
command3 (bo) OUT --PP-NMS--> B2
You don't have to set all bits at the same time in this case.
In cases where we have to set the command word as a whole we don't use
the mbboDirect, but a calc record (to gather/shift/invert the command
word) that writes to a longout record accessing the hardware.
Ralph
- How to use mbboDirect ? Steve Hunt
- Re: How to use mbboDirect ? Ralph . Lange
- Re: How to use mbboDirect ? Steve Hunt
<1999>
<1999>
