1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to use mbboDirect ?
To: Steve Hunt <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 26 Nov 1999 19:20:12 +0100
Thanks Ralph for putting me on the right track,
It seems as though the only change to mbboDirect in the new release is in the
mbboDirectRecord.dbd, making VAL and SHFT able to be modified - so commenting out
the SPC_NOMOD line in my .dbd file  seems to work for me:
        field(VAL,DBF_USHORT) {
                prompt("Word")
#               special(SPC_NOMOD)
                pp(TRUE)
                asl(ASL0)
Steve
Steve Hunt wrote:
> Thanks Ralph,
> I am not going  to upgrade our systems at the moment (we are just commisioning
> our Linac !!!) so:
> - can I upgrade just this record, or does it need new features of this release
> - is there another way to write a value to this record so that it sets all its
> outputs at the same time ?
> If this did not work before - ( and it has been around a few years)  I can't
> understand what was the use of this record ?
> Steve
> [email protected] wrote:
> >   > The 3.13 record ref manual is inconsistant with the doc on the cebaf
> >   > ftp site - the cebaf doc (probably 3.12) defines VAL as a USHORT,
> >   > the 3.13 doc defines VAL as a ENUM, and my .dbd file also defines
> >   > VAL as a USHORT.
> > ENUM is complete nonsense - Bob, will you put this on your ever-growing
> > list of Record Reference Manual errata?
> >   > what am I doing wrong ??????
> > Actually the answer was already included in your mail:
> >   > I am running 3.13b12
> > Because if you look closely enough at the release notes for 3.13.1, you
> > will find:
> > ----- 8< -------------------------------
> > devMbbiDirectSoftRaw, devMbbiSoftRaw, devMbboDirectSoftRaw, devMbboSoftRaw
> > SHFT was made a prompt field and also modifiable.  The VAL field of
> > mbboDirectRecord is now modifiable.
> > Hope this helps,
> > Ralph
How to use mbboDirect ? Steve Hunt
Re: How to use mbboDirect ? Ralph . Lange
Re: How to use mbboDirect ? Steve Hunt
Prev: Re: How to use mbboDirect ? Steve Hunt
Next: Re: PV's on the www Arne Freyberger
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: How to use mbboDirect ? Ralph . Lange
Next: Interrupt routines Mark Rivers
